Multimedia Exchange - 421 Solid Roller Dyno Vid 608 RWHP
antz01ta
11-22-2008, 05:48 PM
Finally got to post up the dyno videos from the car. The thing drives great and runs on pump gas.
I'm not telling you it drives like stock, but for what it is it's not bad.
2001 Trans-Am WS6 M6
421 Iron Block
12.5:1
ETP 255’s
Rapid Motorsports Dominator Solid Roller Cam
Jesel J2K 1.7’s
Beck Sheet Metal Intake
Fast 90mm
Pump Gas
Kooks 1 7/8 x 2 x 3 ½ stepped headers with off road pipes
Kooks Y-pipe
Mufflex 4” catback
Textralia Twin Disk
D&D Viper Spec T-56
Denneys nitrous shaft
Moser 12 bolt, 4.11 gears
608rwhp 496rwtq
The rattling you hear is the broken exhaust cutout, the shaft was broken and rattling like crazy
Dyno 1 (http://www.antzenergy.com/pictures/Dyno1.wmv)
Dyno 2 (http://www.antzenergy.com/pictures/Dyno2.wmv)
'Trust'
11-22-2008, 05:56 PM
Nice numbers!! TQ seems a lil low though?
bad95killer
11-22-2008, 05:57 PM
Very impressive numbers man....Congrats :cheers:
Do you have the Graph ?!
peace
Redlinez
11-22-2008, 05:58 PM
Frickin awesome man!!!!!
03 BUSA
11-22-2008, 06:04 PM
It's about time. Need to teach em how to strap that thing down properly. Would like to hear more idle but still badass.
antz01ta
11-22-2008, 06:17 PM
now that i got the computer figured out i can get some idle clips.
give me a day or 2.
antz01ta
11-22-2008, 06:19 PM
http://www.antzenergy.com/pictures/Trans-Am%20Dyno.jpg
03 BUSA
11-22-2008, 06:41 PM
give me a day or 2.
Thanks man.
KCFormula
11-23-2008, 09:46 AM
Thats the beck intake. I'll have to get a graph of mine up and you can see there is a huge difference in tq. but the trade off is peak hp.
What are the specs on that cam? It sounds pretty tame, or is it the catback?
03 BUSA
11-23-2008, 01:35 PM
[QUOTE=KCFormula;10532363]Thats the beck intake. I'll have to get a graph of mine up and you can see there is a huge difference in tq. but the trade off is peak hp.
QUOTE]
It is also the 4" exhaust with big stepped headers but like you said the trade off is peak hp which is what I think he wanted for his purposes. I also thought it sounded very tame down low, that is why I asked for a separate idle outside vid.
blackbird-TA
11-24-2008, 01:31 AM
pretty mean set up what i would like to know is every body i talk to a bout cams when i say i want to go with a solid roller build up every body say's it will not last ???? and will give me a bunch of problems what do's a solid roller cam do so bad i think the sound and hp gains would be way.. better
i would love to see hear some idle/rev clips and drive by's @ WOT.....
antz01ta
11-24-2008, 05:18 AM
A solid roller is fine as long as you keep an eye on valve clearance and pull a spring once in a while to check pressures.
I have the videos of idle and a rev, I'll post them up later today, not gonna see a drive by, it snowed the other day and there is salt on the road, the car is in the garage for the winter.
antz01ta
11-24-2008, 05:21 AM
it's a 260/266 .700/.700 112
as said above it has 1 7/8 - 2" step headers and a Beck intake so the torque is low but hp stays flat all the way to 7500 rpm.
with that said until the car is in 3rd gear you can't put the throttle on the floor unless you want to have the tires go up in smoke, more torque down low would be usless anyway for the street.
03 BUSA
11-24-2008, 11:57 AM
Looking forward to it. Very cool. Thanks man. :D
antz01ta
11-24-2008, 06:36 PM
Here you go guys, video as requested and i also threw in a couple pictures.:D
Idle Clip (http://www.antzenergy.com/pictures/Idle Clip.wmv)
My favorite part of the Rev clip is how slow the stock tach is.
Quick Rev (http://www.antzenergy.com/pictures/Quick Rev.wmv)
http://www.antzenergy.com/pictures/Underhood Pic.jpg
http://www.antzenergy.com/pictures/Side Shot.jpg
03 BUSA
11-24-2008, 06:48 PM
That's thing looks and sounds great. That is much better than the previous vids. Great job man, looks very proffessional.
antz01ta
11-24-2008, 06:52 PM
Thanks, I have a lot of time into it and I think it came out decent.
By your sig it looks like you will have a great setup too, be sure to post it up when you get it done.
03 BUSA
11-24-2008, 07:01 PM
Will do. Not sure on intake just yet and the cam will be slightly smaller with mid 700's lift on a 110 and 1.8 rockers. Same compression right around 12.4 or so. Should be done in the middle of winter. Yay! I will def post up when done. Whose v.covers are those? They look really good on that setup.
ChevyWeatherman
11-24-2008, 07:07 PM
its the tits
antz01ta
11-24-2008, 07:08 PM
Thanks
They are Moroso
MTBSully
11-24-2008, 09:33 PM
is that a mufflex 4" catback with spintech muffler? I have the same setup and i really like the sound so far
blackbird-TA
11-25-2008, 04:17 AM
that my friend is one sexy beast thanks for the info on the solid roller cam.
im trying to put a 427 solid roller in my car
and maybe a 12bolt or 9'inch rear.
talk is cheap getting it done is the hard part.lol
nice car man let us know this spring what kind of numbers it puts up..
antz01ta
11-25-2008, 05:26 AM
yes it is, i've had this setup for about 4 years now and love it.
antz01ta
11-25-2008, 05:31 AM
Thanks
I'll post up in the spring what it does, I'll also get a video too.
mikey
11-25-2008, 07:05 AM
Looks and sounds great Glenn.
antz01ta
11-25-2008, 08:11 AM
Thanks Mikey, and thanks for a great tune.
03 BUSA
11-25-2008, 11:21 AM
Was that intake custom made for the use of the fast t/body?
antz01ta
11-25-2008, 12:25 PM
every intake is custom made from Beck, you order it for whatever you want to use.
I also had him put nitrous bungs in it, I have a NX Direct Port kit for it with 300hp jets. Don't think I'm going to put it on, but you never know. :devil:
03 BUSA
11-25-2008, 12:26 PM
Nice!
03 BUSA
11-25-2008, 01:58 PM
Have you run this motor with another intake on it by chance?
antz01ta
01-09-2009, 12:34 PM
No, Ive only used this one
99_Z28
01-09-2009, 01:39 PM
:hail::hail:
Any strip action vids by chance?
antz01ta
01-09-2009, 01:40 PM
no, were getting 10" of snow tonight, that won't happen until april or may.
NHRAMAN
01-09-2009, 01:56 PM
Very cool...sounds real mean...:devil:
03 BUSA
01-09-2009, 03:55 PM
Nice, thanks for getting back to me 9 weeks later. LOL. Just messing with you. Sorry bout the snow though.
Medic/Z28
01-09-2009, 08:56 PM
SICK ASS CAR! Sounds awesome.
RacerXLs1
01-09-2009, 09:39 PM
Man that think is mean.
venom ws7
01-09-2009, 11:39 PM
Sounds sick man I cant wait for some track vids.
00T/AWS6
01-10-2009, 02:04 AM
damn that thing is soooo sexy, where at in PA are you?? I wanna see some track passes from that thing!!
HDon22s
01-10-2009, 06:50 AM
Car is sweet but prob have a hard time gettin any street action lol.
MonmouthCtyLS7
01-10-2009, 07:53 AM
Very Nice!
