kyb agx (again)
Old 11-22-2008, 08:46 PM
juiceTA's Avatar
Exclamation kyb agx (again)
i found this post in a thread and it was unanswered.
Originally Posted by C_Rules
i installed my rears but im concerned. these shocks compressed very easily by hand. i had kyb gas shocks before and to compress them i had to push them against a solid object. i was able to compress my AGX's by hand on both the 1 and 8 setting. are they supposed to be this soft? i
i am about to install a set fo used agx in my car and compared to the decarbon's i just pulled out its like night and day with the compression rate and return rate... agx can be compressed with one hand, and take a long time to return... and the decarbons need 2 hands and quite a bit of force to compress and return in 5 seconds. can anyone explain this?
Old 11-22-2008, 09:13 PM
99Bluz28's Avatar
Lightbulb
Here's some info.:
http://www.kyb.com/technical/faq/faq02.php
Also, I think since they're single adjustible the adj. **** only adjust the rebound, not the compression dampening.
Somebody, Please correct me if I'm wrong!
Old 11-22-2008, 10:02 PM
fast377's Avatar
They adjust compression and rebound with the same ****. That's part of the reason why you can't get them to act the same as konis.
Old 11-23-2008, 09:36 PM
juiceTA's Avatar
thanks guys
Old 11-24-2008, 04:00 PM
LS1TECH Sponsor
Sam Strano's Avatar
Originally Posted by 99Bluz28
Here's some info.:
You're wrong...
They are single acting (one ****) double adjustable (the **** effects both sides of the damping).
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Quick Reply: kyb agx (again)
