lowering car today
Old 11-23-2008, 10:44 AM
crossroads's Avatar
Default lowering car today
I'm lowering my 98 camaro today & putting some Spohn sway bars also....does anyone have the torque specs for all these items.....Ls1 how to still isn't up and running and im not getting what i need from a search
Old 11-23-2008, 12:46 PM
Major_Lee_Slow's Avatar
Here ya go (All in Ft*lbs):
Brakes:
Front
Caliper Mounting Bracket Bolt: 74
Caliper Guide Pin Bolt: 23
Rear:
Caliper Mounting Bracket: 75
Caliper Guide Pin Bolt: 27
Front Suspension:
Endlinks: Tighten till nut seats on bolt shoulder, then give it one more 1/2 turn
Anti-Roll Bar Body Mount 55
Shock Lower Bolts: 48
Shock Mount Upper Bolts 37
Shock Mount Upper Nuts 32
Upper Ball Joint Nut 72
Lower Ball Joint Nut 81
Tie Rod Outer Ball Joint Nut 35
Rear:
Shock Lower Nut: 66
I think that should cover all of the fasteners. If I'm missing any just post in this thread.
Old 11-23-2008, 01:27 PM
99Bluz28's Avatar
Thumbs up
Brakes:
Front
Rear:
Front Suspension:
Upper Ball Joint Nut 72 Wrong This is 39 lb ft.
Rear:
Shock Lower Nut: 66
The correction I made is out of a 1999 serice manual.
The incorrect torque spec you listed (72 lb.ft.) is for nuts on the upper control arm mount bolts.
Old 11-23-2008, 01:52 PM
Oops, sorry I looked at the wrong line in my 1998 Service Manual.
I tell yea, the GM Service Manual sets are worth the weight in gold, if not just for the torque specs alone...
Old 11-23-2008, 03:39 PM
99Bluz28's Avatar
Thumbs up
Yeah they are, but I sure wish they would of used some thicker paper for all those pages. I always fell like I'm going to rip a page every time I open 1 of the 3 manuals !
Old 11-24-2008, 06:54 AM
crossroads's Avatar
Thank you for the assistance!....I wound up runnign into a big setback on the last RH front, when i pulled the shock/spring assemble i discovered the top nut that hold the shock together is rusted beyond the point of a nut anymore so today i plan to bust out the torch to cut it all apart......I need that upper plate and none of the parts stores even know when they can have me one
Old 11-24-2008, 08:24 AM
Yea, that's a common problem. The last time I changed my springs I ended up using one of those sockets that bite into the nut. http://www.sears.com/shc/s/p_10153_12605_00952165000P
When you re-assembly the car a nice trick to reduce rust in the future is to pack grease into this area. I've done this ever since the first time and it seems to help.
Old 11-24-2008, 08:40 AM
crossroads's Avatar
those are awsome.... i might try that before i get to cuttin', and thanks for the tip with the grease!!!
