Plug Reading
Plug Reading
What would this plug indicate to you guys?
The plugs were brand new gapped .29 TR6's with approx 70 miles on them. Its a Whiteish coating (very thin) with a blackened base ring. The whiteish coating scrapes off with a finger nail.
The car runs great in vacuum up until 0 vac or boost then stumbles badly.
The tuner (nicD) said everything looks great on the tune and AFR's are good. No codes.
I'll give more details after I finish the compression and leakdown test in a few.
Just got finished with the compression test and leak down.
1-185 2-180
3-185 4-170
5-170 6-180
7-195 8-170
All cylinders less than 5% leak down. although i can still smell the oil smell being pushed up through the breathers on the leakdown test. I can also kinda hear it coming from breathers.
Any ideas?
Anyone else have this problem when going into boost?
I only have two things left to try. A new Map sensor and a fuel pressure gauge to read while driving.
1-185 2-180
3-185 4-170
5-170 6-180
7-195 8-170
Any ideas?
you cannot read a gas plug by just looking at it...
methanol yes, gas no
the thread has to be cut off, and the fuel ring looked at , right down the bottom of the white porcilin.
or
an eye piece , magnifing glass used to look down inside the threaded section
the only thing read on gas plug is the timing mark on the electrode.
ash
or
ash
