Remove AIR pump?
Old 11-23-2008, 03:27 PM
shutzero's Avatar
Default Remove AIR pump?
Hey I put long tubes on and i just ended up capping off the air and EGR stuff. someone told me i could remove the AIR pump. is this true? im just trying to figure out what i can remove before i do it so i dont **** anything up lol
Old 11-23-2008, 03:30 PM
97lt1camaro's Avatar
I took everything associated with my air pump out. Metal line under the motor also. Only thing still there in the electrical connector hehe. Spare parts, give er' !
Old 11-23-2008, 03:31 PM
shutzero's Avatar
so i can take the black AIR pump itself right off?
Old 11-23-2008, 03:34 PM
robsquikz28's Avatar
yes can unbolt it and all the retaining hoses and metal piping just the connector leave on.....
Old 11-23-2008, 03:37 PM
shutzero's Avatar
connector?
Old 11-23-2008, 03:41 PM
sweetbmxrider's Avatar
do you need a different belt size or what?
Old 11-23-2008, 03:49 PM
ThreeHonks's Avatar
no it doesnt run off the belt, just pull everything out thats has anyhting to do with air/egr
Old 11-23-2008, 03:53 PM
shutzero's Avatar
ok and do i need to cap anything off? like the cai where that tube came off of
Old 11-23-2008, 04:08 PM
oh **** you are right haha. that was my truck that was belt driven. yeahhhhh just yank it out!
Old 11-24-2008, 07:21 AM
ThreeHonks's Avatar
Yes you will need to cap off the line that goes from the air pump into the cai intake tube. There is also a small fitting on the inatke manifold that has two vaccum fittings coming off of it. Trace all the vaccum lines from this and pull anything off that connects to it. One line will lead to the air pump in the front of the engine and the other will lead to the rear (near the egr) pull all of this off and you are just fine. I will take pics of what everything looks like for you if I can get my camera to work
Old 11-24-2008, 09:55 AM
SoxXpupPeT's Avatar
remove everything and cap your headers. call it a day. cleans up alot under your hood too!
Old 11-24-2008, 10:04 AM
the_merv's Avatar
Then if you want to you can clip the Connector and clean that up too.
Old 11-24-2008, 05:02 PM
ThreeHonks's Avatar
IMO dont cut any wires, just hide them away in case you sell the car and the next owner wants to bring it back to stock, you also wont run the risk of grounding out wires
Old 11-24-2008, 06:16 PM
I8ASaleen's Avatar
Get rid of it. You can go to O'Reilly's and pick up an assorted vaccuum cap set for about $3 and it will have one for the air intake and intake manifold.
Old 11-25-2008, 04:33 PM
Bowtie_Aaron's Avatar
is there any performance gain with removing just the air pump?
its just a plug, 3 bolts, and an ugly tube that goes from driver to pass side under the oil pan.
aaron
Old 11-25-2008, 04:51 PM
ThreeHonks's Avatar
not really any performance gain but it makes the engine bay look a ton nicer!
Old 11-25-2008, 05:01 PM
thats what i was thinking. one day ill take it out..
aaron
