Generation IV Internal Engine - A few ls2 questions???
View Full Version : A few ls2 questions???
silverz28camaro
11-23-2008, 10:36 PM
I am looking into putting a used(hopefully good) into my 2000 a4 camaro.
What all do i need? is this a simple swap and re-tune? I would be re-usinf my ls6 heads i have on my ls1 and i would definitely be going with a bigger cam.
What will compression be with my ls6 heads? Actually my ls6 heads cam off of a 2007 ls2 corvette if this helps.
I now have a 224 227 cam in my ls1, what would be worth buying for the ls2?
Also what is the rpm limit of the ls2? is it as strong as the ls1 as far as bottom end goes.
And finally....Is this worth doing?
dlove
11-23-2008, 11:08 PM
ls2 has flat top pistons like an ls1.
with rod bolts, around 7k is fine. stronger than ls1 stuff. pistons/rods are floating and not press fit like ls1. valvetrain is the limit of the rpm usually
that cam would work if you are on a budget but I would go bigger.
Detroitmuscle
11-24-2008, 11:40 AM
I'm pretty much doing the same thing this winter as was curious as to how many others have done it and what kind of ETs and numbers are they making with H/C? I'll be swapping in a stock shortblock as well.
frito1
11-24-2008, 06:14 PM
These are good questions and I'm looking forward to the complete answer. I'm looking at throwing a L76/LS2 shortblock in and bolting my heads and intake on. What all do I and the OP have to do to make this work? What about the difference in 24X wheel vs the 58X or whatever it is? Is there any sort of easy plug and play conversion or do I physically have to press the 24x wheel on the L76 crank to work with my computer?
gectek
11-24-2008, 06:23 PM
gm is supposed to be working on the 58-24x conversion harness...but you will need a cam/knock sensor extension harness and i would prob use the better knock sensors from the LS2 and up. use the LS2 valley plate too. then you need to see if that LS2 is 24 or 58, i have heard there are some of both. thats really it...the LS2 and the LS6 are almost the same, just the valves are diff
frito1
11-24-2008, 08:52 PM
^^ Thanks for the info! I think the '05 LS2's are 24x. The rest are 58x I believe. If anybody knows anything else about the 58x to 24x conversion, I am interested to hear it! Also, my AFR heads, Kooks headers, accessories, engine mounts, etc should all bolt up just fine, right?
EDIT! Found some good info...
http://www.ls1tech.com/forums/generation-iii-internal-engine/659189-ls2-conversion-info-inside.html
1sick'98WS6
11-24-2008, 10:44 PM
You will need:
24tooth wheel, The machine shop fits them for like 40 buck
A cam/knock sensor extension harness, its the same harness like 45 bucks
Ls2 valley cover/ and switch your oil pressure sending unit with your current
drill and tap for relocating knock sensors to side of block
front cover for relocated cam position sensor
also swap in your existing ls1 crank sensor to read the 24 tooth wheel
Also on most of the harness for the cam sensor you have to swith the wire pins on the pink and brown and white wire to make your car start( other wise it wont work and will take like 30 tries to start it. lol I know
89Formulaws6
11-24-2008, 11:16 PM
^^ pretty much covers it, im doing a short block into my corvette this winter as well
depending on the year of the ls2 the cam shaft sproket & tensioner has to be changed on the 06+ ls2's
gectek
11-25-2008, 08:40 AM
You will need:
if he already has an LS2 block...most of what you said he already has. and if its an 05 then he has the 24x and doesnt need to swap. he will have the front cover, valley and knock holes and the 24x sensor, also i believe that the crank sensors are the same on the GTO LS2s...
plus afaik the tensioners are the same
Detroitmuscle
11-25-2008, 09:34 AM
Sounds like a pretty basic swap, does anyone have a direct link to the harness from either SDPC or TSP I'd like to start gathering parts.
gectek
11-25-2008, 09:42 AM
CAS109081
CASPERS harness adapter from SDPC $59.95
silverz28camaro
11-25-2008, 12:34 PM
You will need:
will the harness take care of this, from casper
gectek
11-25-2008, 12:36 PM
the harness should be plug and play completely
Detroitmuscle
11-25-2008, 01:20 PM
I'm confused a bit as well, if I already have the front timing cover off a LS2 and it has the cam sensor in it would I replace that one with my LS1 sensor, or does the harness reverse the wires so I can use the LS2 sensor?
gectek
11-25-2008, 02:07 PM
use the harness and the LS2 front cover with the sensor that comes in it...the harness will take care of the rest
Vndcatr
12-09-2008, 08:37 PM
And if its a complete longblock stock ls2 from an 05 c6.. then nothing is needed besides the extension harness ??
Also will my kooks bolt up to this block ?
gectek
12-10-2008, 10:21 AM
bolt pattern is the same on the exhaust...intake as well from LS2 to LS1/6...
all you need is the harness yes
1sick'98WS6
12-10-2008, 11:06 AM
The harness will still need to be switched. Pink pin switched with brown and white. Most of the caspers harness need to be switched, its no big deal but from everyone I talked to they ended up switching the wires. Check to see that it starts just fine first try, if it is taking multiple times to start, or if the tach is not responding switch wires.
