K-Member Install Cost
Old 11-24-2008, 02:53 PM
2002 Trans Am's Avatar
Default K-Member Install Cost
What should I expect to pay to have a stock or tubular k-member installed?
I had my car aligned on Friday because it was pulling hard to the right after I lost control in the rain and jumped a curb.
The guy doing the alignment commented that I bent the frame (it was the K-Member he was referring to) and said it was hard to get it setup. Well it still pulls to the right and I am thinking I may need a new K-Member because it is pushed up (not in toward the center of the car)
I'll probably end up taking it to one of the performance shops in Northern NJ, but I kind of wanted to get a ball park 1st.
I'll try to get a pic tonight.
Old 11-24-2008, 02:56 PM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
Should be in the ballpark of 4 to 6 hundred (labor only) depending on who you go to.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 11-24-2008, 03:07 PM
Jesus Christ...$400 - $600
Old 11-24-2008, 03:12 PM
slayerized6's Avatar
i would say 6-8 hours of labor. i would assume you have to drop the kmember with the engine and everything esle attaches and just transfer everything to the new kmember. and if they don drop the kmember, here the time to easily to a heads/cam, headers, bolt ons etc.
Old 11-24-2008, 03:38 PM
Moderator
jimmyblue's Avatar
Yeah, my install was supposed to be 8 hours of shop
time and took a bit of overtime to get done. That
included poly motor mounts and an alignment but
still, it's a lot of work. The motor stayed with the
car (pedestal jack, car on lift).
Old 11-24-2008, 03:47 PM
BMR Tech2's Avatar
Have a different shop check to see if your k member is bent. Also have them check to see if its your a arms. They tend to bend easier than the k member. It never hurts to have a second opinion.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 11-24-2008, 04:37 PM
Yeah I plan on it, the alignment shop was a gas station / service center so I'll try out a performance shop for their opinion.
Going to post pics in a few minutes...Heading to the garage now
Old 11-24-2008, 05:50 PM
leadfoot4's Avatar
Just my $0.02 worth...I'd skip the performance shop, and go to a body shop or heavy truck repair shop. Someplace that has a frame machine, and the refrence data for the F-bod.
Old 11-24-2008, 05:55 PM
I don't know, I was just under there and it looks all peachy aside from the dent in the K-Member
Upper and lower control arms look intact with nothing that appears to be bent. Here is a bunch of photos I snapped, I'm sure you'll guys will mention the power steering rack "sweating" is that an issue?
Don't mind the fluid all over the parts, the curb took out my B&M Trans cooler which was located in front of the passenger wheel in the bumper.
Old 11-24-2008, 08:31 PM
BMR Tech's Avatar
If you curbed it hard enough the spindle is probably the culprit and is bent........
Old 11-25-2008, 02:02 AM
35th SS's Avatar
looks like the lower a arms moved on you looking at the pics.
Old 11-25-2008, 03:09 AM
robsquikz28's Avatar
looks like lower a arm to me but it could be spindle or even bent tie rod but hey those are pics bring to a firestone or even a a very dependable alignment shop
Old 11-25-2008, 08:39 AM
leadfoot4's Avatar
In the one picture, it obviously shows that the K-member took a good shot. That impact was tranmitted to the rest of the unit-body. I'll again suggest a trip to the frame machine, just to be sure the front of the car isn't "tweaked"...
Old 11-25-2008, 09:59 AM
Thanks, I guess I'll do that.
Old 11-25-2008, 10:12 AM
YellowToy/A's Avatar
ouch I would at the lower arms along with the K-member. I hope you did not tweak the unibody. I would not bet on it. It will cost to get it right. How much u do not want to know.
Old 11-25-2008, 10:49 AM
If you had to ball park, what would it cost?
Old 11-25-2008, 02:33 PM
leadfoot4's Avatar
Most shops charge by the hour. I would assume (bad word)that they would probably start around an hour to an hour and a half to get it on the "rack" and measure everything. After that, if it's just a little tweaked, it would make sense to pull it out, since the car is already set up. That might be another hour or so, maybe??
Old 11-25-2008, 03:38 PM
I'm going to a body shop tomorrow to have them check it out.
Crossing my fingers that this doesn't cost me too much
Old 11-25-2008, 03:50 PM
BMR Tech2's Avatar
Good luck!!
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old 11-25-2008, 03:54 PM
Good luck!!
Thanks, I'm gonna need it. I truely love my car and this has been very frustrating.
If I can get by with only spending a few hundred on the frame, I might just go all out and replace the control arms, spindle, and K-Member.
Do they make lighter/stronger spindles?
Quick Reply: K-Member Install Cost
