Flywheel bolts backed out again! 2nd time!
I'm not sure of whether this is a clutch/flywheel problem or and internal motor problem so heres the link to my post in the Manual Trans section:
https://ls1tech.com/forums/manual-tr...l#post10541673
This is fairly common on higher power engines of any type. My best results have been using the crank dowel to locate the flywheel/flexplate, then proper torque for the bolts you are using with loctite.
Kurt
Kurt
