My afternoon Project
The rules seem to change a lot from year to year. But the engine must be a GM or Ford Crate Motor. The one thing I love about this car is the Quick Change Rear End. So you are able to change the Gear Ratio of the Rear End without changing the whole rear end
That inspection plate comes off and behind it are two gears, One Big/One Small. By changing out the size and teeth number of your gears you can change the gear ratio of the rear end. Takes less then 15 min to do.
