View Poll Results: Which Rings for Turbo Engine?
Speed Pro HellFire
26
55.32%
Total Seal Gapless Top Ring AP
21
44.68%
Voters: 47. You may not vote on this poll
Rings...
I would NOT run gapless on a FI application.
We run a stainless top ring (usually standard wiseco rings) with alot of boost setups. After that we goto a hellfire or custom ring set
We've used both with good results. Mark switch to a gap less ring and the car picked up 2" of vacuume at the finish line. Car ran 6.40 @224 I think personally they helped performance.
Hellfire rings are lot easier on the bores then AP rings, but don't count out plasma moly rings either, 1,000rwhp I would use them, if you're burning the moly off theirs something else going on.
I went with hellfires and only have maybe 300 or 400 miles on them and now car is put away. They seem ok not noticing any oil coming out the back . I had a few problems with my car so did idle it a bit more before driving but again they seem fine. I get some piston slap for a few minutes when engine is cold but not blaming the rings for that.forged pistons are going to make some noise and talking really cold right before put car away for few weeks since got car done. My car is street car not track car so hope the hellfires are street friendly. As said if don't see smoke out the back like one guys nitrous lt1 build will be happy camper. They must have really set up his rings loose or something it was embarrassing for him.
I am running the Diamod plasma moly rings that came with my Diamond -8.6cc boost pistons,
but i heard that diamond dont make them someone else does,
My engine builder siad that a chrome moly top ring is the way to go and use what diamond sent me.
