real help for modified sts
Old 11-25-2008, 12:14 PM
ironhorse583's Avatar
Default real help for modified sts
b4 any1 get on here and barks do a search i have...............
so whats the real advantage of running the stock manifolds on the sts set up????i know the manifolds retain heat alot better but what is the real world diff in rpm??? lets say a sts car with headers doesn't reach full spool till 4000 rpm...everything being equal and only changing to a stock manifold what would be the rpm diff....would it reach full spool at 3000 rpm??? if the change from headers to manifolds is only a couple hundred rpm it really would not be worth the pain of changing...has any1 made the change from headers back to manifolds and have real proof of the diff....dyno or track times
Old 11-25-2008, 01:30 PM
67Firebird455's Avatar
I saw a difference of about 500-600 rwhp on my rear mounted T70 going from ceramic coated LT's to manifolds. I plan to run truck manifolds flipped in the next build since they work so damn well and are good to 1000+rwhp.
Old 11-25-2008, 02:27 PM
5-600 thats a pretty good diff....
Old 11-25-2008, 02:28 PM
also who has the fastest 6speed rearmount turbo fbody....
Old 11-25-2008, 03:25 PM
hmmm, not sure these days, I know longrange4u used to have a TA that would HAUL *** with a rear mount.
Old 11-25-2008, 08:55 PM
smoke20's Avatar
When I switched from headers to manifolds the boost came in about 600 - 700 rpm sooner. Its a huge difference , and its one of the easier swaps to do that makes an advantage. I got my stock manifolds given to me and I sold my headers and Y-pipe. I spent more swapping a cam to gain 30 hp.
Old 11-26-2008, 11:10 AM
OUTLAWZ RACING's Avatar
Me thats Who Jk !. Go with the stock folds and u will love it. It was a differance of night and day between my midlenths wrap and my 02 folds wrap. I can say this when boost hits on my car it hits hard. I seen a differance in spool rate also she picks up fast around 3k. I also get 12 psi in first gear with 3.73 so yes stock folds are worth it.
Old 11-26-2008, 11:35 AM
kbracing96's Avatar
It's not the dyno or the track that you'll notice the most improvement, its on the street. When I had the STS on my truck, just wrapping the pipes with header wrap from the manifolds back to the turbo, made a HUGE improvement in butt feel and spool time on the street.
You don't see so much difference on the dyno or at the track, because you are spooling the turbo before you make the pull or the pass.
Old 11-26-2008, 05:34 PM
ok thanks for the responses....
my idea is to put stock c5 z06 manifolds ( i believe they flow better and will fit on my ta ) into a custom y pipe into the single pipe that leads into the turbo...the manifolds will b ceramic coated as well as all the hot piping...out of the manifolds what size piping would u suggest going with??? 3in out of the manifold to the y then to 4in or 3in the whole way????
Old 11-26-2008, 06:38 PM
kbracing96's Avatar
Smaller pipe will keep velocity up and heat loss down and help with spooling and pressure drop. I'd run 2 1/2" from manifold to y, then no more then 3" back to the turbo. Personally, unless your building an all out drag car, I'd run 2 1/2 or 2 3/4 to the turbo.
Quick Reply: real help for modified sts
