Help me decide on a cheap rear...
Old 11-25-2008, 01:06 PM
Shirley Temple Drinker
Sgt. Spuds's Avatar
Default Help me decide on a cheap rear...
Alright I wanna do something soon, the 10 bolts not gonna last 2 much longer... What would be the lightest choice with least amount of parasitic loss, and cheapest rear end? I'm thinking a 9 inch with a spool, correct? Or would a 12 bolt suit my needs alright?
Old 11-25-2008, 01:09 PM
z28rob18's Avatar
talk to midwest chassis they hav a great price on there fab 9"
Old 11-25-2008, 01:21 PM
Racin96ss's Avatar
From what I hear Strange S60/spool
Old 11-25-2008, 01:22 PM
camaro-94-z28's Avatar
can you say cheap and rear end in the same sentence? didnt know that was possible.
Old 11-25-2008, 01:25 PM
z28rob18's Avatar
its not but least expensive of all companies would work lol the s60 is cheap but if u think about it the midwest fab 9" weighs about the same as the 10 bolt and it comes with a chromoly torque arm and u can get a driveshaft upgrade with it for und $3k add the cost of those things with any other rear and they r more expensive
Old 11-25-2008, 01:39 PM
kinglt-1's Avatar
I was going to say the same thing! Midwest does make a killer unit, it's not cheap, but is as light as the 10bolt.
Old 11-25-2008, 01:56 PM
Sgt. Spuds's Avatar
I didn't mean cheap, I know I'm gonna be over 2 grand easy, but I wanna stay as close to that as possible... The D60 is cheaper than the 9 inch? I thought they were a little more, aren't they stronger but heavier than a nine inch?
Old 11-25-2008, 01:59 PM
z28rob18's Avatar
the s60 is about 2500 after all the needed upgrades and thenu need to buy a driveshaft for it i think its stronger but u will lose more hp with it then a 9"
Old 11-25-2008, 04:02 PM
Sgt. Spuds's Avatar
Think I'm going with the midwest chassis set up, seems like a good deal, thanks guys
Old 11-25-2008, 04:15 PM
Bowtie_Aaron's Avatar
you could do a stock rear with axles and a studded cover with mikronite gears, thats what im doing next, but mines auto.
a 12 bolt would be your next best as it only takes something like 10% to turn, and 19% with a 9", dont quote me, its been a while since i read the article on it in Chevy High Performance.
for performance rear, a 12 bolt is what i would go with, but thats only me.
aaron
Old 11-25-2008, 04:17 PM
AChotrod's Avatar
S60 for sure..... and even with a true track I only lost 13.5 hp and 12.38 Tq at the tires thats with 35spline axels.
Strongest rear out. Most options and under 3k with DS rated to 800hp.
Old 11-25-2008, 04:45 PM
hashtagBMW
Speed Density's Avatar
Just pickup another stocker if your on a budget. I dont think with a mild H/C like yours I would buy a $2,000 rear.
Old 11-25-2008, 05:24 PM
AChotrod's Avatar
If hes at the track alot and since he is a M6 Its only a matter of time!
Old 11-25-2008, 05:36 PM
97T/A's Avatar
Currie 9 Inch rear end for around $1600 and can handle up to about 8-9 second 1/4 mile passes
Old 11-26-2008, 09:10 AM
n2ocamaro's Avatar
Where can you get a Currie for $1600? I have not seen a complete Currie rear for less than $3000.
Old 11-26-2008, 02:48 PM
Sgt. Spuds's Avatar
I've chucked a 10 bolt already on stock power, and my car sees just as much track time as it does street time.... Plus I plan on a turbo ls1 after this motor goes...
Old 11-26-2008, 11:43 PM
brucealmighty744's Avatar
here is a link where it shows how you can get a complete bolt in 9 inch for $1,917 using the best quality parts, price includes some labor too. http://www.lt1howto.com/articles/diy9inch.htm
Tell me what you guys think.
Old 11-26-2008, 11:53 PM
Sgt. Spuds's Avatar
I think I might just order a 9in housing n axles of the web, find my center section locally, I imagine I can get a complete one for pretty cheap slightly used...
Old 11-27-2008, 01:27 AM
engineermike's Avatar
I put a 9" in my car for well under $1500.
I used a new housing and axles from Moser. I bought a used 9" chunk for $50 from an old racer. It's the non-desireable cast iron one, but still much stronger than a 7.5". Then, I put a new set of gears, limited slip, and bearings in it. Cheap and strong!
Mike
Old 11-27-2008, 01:53 AM
the_merv's Avatar
I have a complete Moser setup under my Car for $2225 invested.
Quick Reply: Help me decide on a cheap rear...
