Inner tie rod replacement
please define "the whole asm!"
you have to remove the outer tie rod and the tie rod boot with its two assoc clamps. Then you will have to push back a plastic cover and unscrew the tie rod.
I would suggest trying to get ahold of another new stainless steel clamp for the boot. it might leak otherwise. they only come from the dealer and are expensive unless you get a replacement boot from another store.
