Which cylinder head parts from a 6.0 will work with L92's?
Old 11-26-2008, 11:27 AM
tennerv8's Avatar
Default Which cylinder head parts from a 6.0 will work with L92's?
I was just curious what parts from a stock 6.0 cylinder head will work with L92's? I know the intake rockers wont but what about the exhaust rockers? Do the 6.0 heads have the rocker support stands on them stock? Are the rocker bolts interchangable? Thanks fellas.
Old 11-26-2008, 12:28 PM
camarols1's Avatar
The 6.0 exhaust rockers and rocker bolts are the same as the L92.
The stands (#12600936) and intake rockers (#12569167) are LS3/L92 specific.
Old 11-26-2008, 01:23 PM
Jon@Texas-Speed's Avatar
Correct. Exhaust rockers and bolts are reuseable but everything else is different. You can move your springs over probably if you wanted to.
Jon
Old 11-26-2008, 01:34 PM
tennerv8's Avatar
How about the retainers and locks?
Old 11-26-2008, 02:43 PM
camarols1's Avatar
The retainers and locks are the same as well.
Old 11-28-2008, 05:41 AM
the_merv's Avatar
Your Valve Covers will work too, you will have to grind out the Baffles on the Passengers side.
Old 12-02-2008, 10:32 AM
tennerv8's Avatar
So if the exhaust rocker bolts are the same would I need to buy eight intake rocker bolts?
Quick Reply: Which cylinder head parts from a 6.0 will work with L92's?
