12bolt center piece
Old 11-27-2008, 08:08 AM
Aetos's Avatar
Default 12bolt center piece
Hey, I may be able to get a good condition, factory 12bolt piece off a friend for very cheap.
How much better would a factory 12 bolt be then our shitty *** rears? What else would I need to install the 12bolt and what "mods" should I do on the 12bolt to make it stronger? (gonna definitely change the gearing and a limited slip if it doesn't have one).
'99 transam M6
Old 11-27-2008, 09:28 AM
LS1Tech Premium Sponsor
ssvert99's Avatar
a "factory" 12 bolt out of what? and how are you planning on attaching the torque arm?
Old 11-27-2008, 09:35 AM
Aetos's Avatar
Doesn't anybody create axle packages for the 12bolt as they do with the 9"?
Old 11-27-2008, 09:52 AM
ssvert99's Avatar
you can get axles made for anything. you need the f-body spring perches, panhard bracket, lca brackets, and a torque arm mount that was never made into any other rearend other than the 7.5 10 bolt f-body rearend. it's not a axle issue... it's the housing.
Old 11-27-2008, 10:07 AM
Kleeborp the Moderator™
MeentSS02's Avatar
Well put...so to the original poster, are you buying a housing, or the internals?
Old 11-27-2008, 10:24 AM
Aetos's Avatar
I'm not sure if its just the internals or the housing also... I just know its a 12bolt center piece.
Old 11-27-2008, 11:12 AM
EPP
EPP's Avatar
https://ls1tech.com/forums/gears-axl...r-end-faq.html
Read number 7. Bob
Old 11-27-2008, 11:42 AM
All Black SS's Avatar
Only thing with 12 bolts and a 'center piece' like a ford 9" is a chevy rear from the 50's, which is garbage these days.
