Comp Cams XFI 268 cam...
Anyone have experience or heard good/bad results from this LT1 cam...specs are 218/224 .570/.565 (1.6 rockers) 113+4 XFI family. Any thoughts on this cam. Could possilbly go in a 91 RS with an LT1 swap. Stock shortblock, ported heads, bolt ons. Looking for a nice combo that isnt extreme, but not too docile either. Wanna do something different than the usual 501, 503, etc.
My buddy has that cam in his Vette. Didn't dyno as high as we expected but the thing moves out pretty good. Has a very strong mid range, can get away with 6100ish shiftpoints and sounds pretty sleeper. I would go 503 before I would go with this cam however because it exhibits similar drivability but feels a little stronger and sounds better too.
I'd probably go with something a little larger. Maybe a CC305 if you aren't wanting very extreme. 220/230 duration and .544/.544 lift on 1.6's. Or, if you want a sleeper cam, maybe Speed Inc's Cadillac Cam. I've heard very good results from it, and you can't really tell that the car's cammed by listening to it.
Or Comp's rpm ranges are wrong meaning you need more spring than they recommend. Actually you bring up another good point, the rest of you should ignore any valvetrain advise from someone who thinks lift is the key concern. The XFI lobes are very agressive so they beat springs up even if not near max lift.
Trust me I have not made the car do what it has by being stupid.
I once had a sweet Bret Bauer cam that destroyed a set of 918s in 1,400 miles. Caused a failure and ended up dropping an intake valve doing major serious damage to my cylinder heads. Springs were set in at 140lbs on the seat. When we tore it down and tested them the one on the dropped valve only had 88lbs of pressure.
^^Yeah I heard of a few of his .600ish lift cams doing that. Before I went with my heads/cam setup I called Lloyd since that was a concern of mine and he said those problems were with those particular cams (.600ish lift ones) and none were had with the others he was offering. I'm running one with less lift (.570's) as well as my buddy in his 383 and combined we have a few thousand miles on them and everything is great.
My buddy has a decent amount of mileage with his xfi 268 cam and 918's and everything has been great for him. Personally though I think the lobe separation is a little wide for my liking but based off my results with the 503 and his with that cam I would probaly opt for something else just IMO. If it were me I would put out a few extra bucks and just go custom.
"I once had a sweet Bret Bauer cam that destroyed a set of 918s in 1,400 miles. Caused a failure and ended up dropping an intake valve doing major serious damage to my cylinder heads. Springs were set in at 140lbs on the seat. When we tore it down and tested them the one on the dropped valve only had 88lbs of pressure."
I had the 918's and after awhile started to experience valve float. The 918's had dropped down to #95. I think these were among the first batch that Comp Cams recieved after the switch from PAC. Their current 918 spring may be of better quality.
Guys, let me first say I am definitely not a supporter of 918's. I was just making the point that too many people run springs that are on the edge of being too weak for their cams. I ran a set of PRC Platinum duals for over 40,000 miles on 3 different cams in my old 98 Z28.
Cam #1 = TSP 231/237 .598/.595 112 +4
Cam #2 = Comp 238/240 .605/.609 112 +4
Cam #3 = TREX 243/249 .613/.619 110 +2 (in sig)
Never once did I have any trouble or doubt these springs would hold. They were rated to a max lift of .670". I believe in goin a little above and beyond and being undoubtedly safe.
springs
original set of 918's with 7,000 miles on them.
installed height is 1.8"....something many ignore and set 1.7". Valve lash is 1/4 turn.
"If" the 918's start to float I will go with the dual spring PAC.
