Lt1 cam
Old 11-28-2008, 04:29 PM
383racecar's Avatar
Default Lt1 cam
Well heres what i got 1994 camaro lt1 stock susp. 3600lbs with driver,3.73,th350,28tire,9.5 bte 4600stall, the engine is a 383 11.6c.r stock ported heads and intake heads flow 281-194@.600,287-201@.700,58mm tb,36lbs injectors,13/4 headers,3inch ture duals,250 to 290h.p shot of nitrous,the cam thats in the car now is not impressing me, its a custom grind nitrous cam, specs are 105.5 lobe sep. .608 -.609lift 238-248 duration. hydr. roller motor can only be turned to about 7100 do to stock pcm,. The car is a 1/4 mile car running on pump gas 93octane, runs 11.5s-11.7s@ 116-118mph on h.p, and 10.1s-10.2s@ 132-134 on the 250 or 290 shot. What do you guys think of the cam and times the car runs? whats a good place to get a good lt1 custom grind done? All input is welcome thanks..
Old 11-28-2008, 09:40 PM
flyinZ's Avatar
LE, AI, Bret B, Cam Motion, Comp Cams, Ed Curtis, Futral(FMS). Thats just a few guys to start with.
Quick Reply: Lt1 cam
