T62-1 .68 a/r Single Rear Mount
Old 11-28-2008, 05:03 PM
prochargedchevyi's Avatar
Default T62-1 .68 a/r Single Rear Mount
Hey Guys,
I'm making another DIY rear-mounted single turbo application for my vette, and I came across a brand new Master Power T62-1 .68 a/r unit for a couple hundred bucks. I'm wondering if this will be too small for my engine. Even still, it was so cheap I had to jump on it. The guy even threw in an extra 44mm WG.
Here are the specs:
810007 Turbo T62-1 " O " Trim
810008 Cart. Assembly
807382 Turbine Wheel TO4E 58,5mm / 2.30” (Ind. 2.303”/ May. 2.913”)
807407 Compressor Wheel TO4E 60.98mm / 2.40” (Ind. 2.400” May. 3.582”)
801145 Turbine Housing A/R .68 NB085
806032 Compressor Housing .70 TO4E
Let me know what you guys think. I'm shooting for between 460-500rwhp.
Vince
Old 11-28-2008, 05:58 PM
GT67METHV's Avatar
that .68 a/r housing will choke you bad uptop, but spool real effin fast
down low. lol once you fab the system it's easy to upgrade.
that's the easy part...you have all you need for a trial mock up
(hard/fun part) that will run okay on the street till you
pick a true direction. i say "DO IT, DO IT".
Old 11-28-2008, 07:24 PM
engineermike's Avatar
Too small.
Old 11-28-2008, 07:25 PM
NemeSS's Avatar
get 2 of those and go remote TT
Quick Reply: T62-1 .68 a/r Single Rear Mount
