Trouble Code P0106??
Old 11-28-2008, 11:12 PM
skeeters65's Avatar
Default Trouble Code P0106??
2002 F-body LS1 in a 69 Camaro.
Motor has a TSP Magic Stick 3 in it..
Code is P0106 - Manifold Absolute Pressure (MAP) System Performance
What does it mean and what should I do to fix it??
Thanks
Old 11-29-2008, 02:32 AM
OUTLAWZ RACING's Avatar
May need a tune or replace the map. What type of intake is it on? Some of the fast 90 have to be sealed in order not to leak.
Old 11-29-2008, 09:07 AM
shizon's Avatar
Most of the time this is because someone tuned the MAF and not VE.
Old 11-29-2008, 09:09 AM
skeeters65's Avatar
The intake is the stock LS6 intake that has never been off the motor..
Where is the MAP sensor located?
If I get a new one should go to a GM dealer or is a parts store one OK??
Thanks
Old 11-29-2008, 07:32 PM
1_fast_gto's Avatar
The map sensor is located on the back of the intake, as a technician in a dealership i would recommend that you use a GM map sensor. I have seen multiple cases where people come in and have all this aftermarket stuff bought from autozone or napa and the stuff most of the time is bad. I recomend using the GM parts.
jsut my two cents
JOSH
Old 11-29-2008, 09:28 PM
skeeters65's Avatar
1 fast gto,
Should I just replace the MAP sensor or try somthing else first??
Is it common that they fail??
Thanks
Old 11-30-2008, 12:40 AM
1_fast_gto's Avatar
can you look at your short term fuel trims for bank 1 and bank 2? if so. see if the vehicle is running slightly lean. if so you need to look for any vacuum leaks. look at the pcv hose i have seen a few of those recently. if there is a lean condition such as a vacuum leak it will set this code. check for any type o unmetered airflow into the engine. if you dont know what i mean by unmetered airflow im talking about from the MAF sensor to the Intake valves any air getting in anywhere along there could cause this light. i dont see it to be real common that these MAP sensors fail but who knows thats also a possibility.
JOSH
Quick Reply: Trouble Code P0106??
