Video New NA PB 10.400@128.96 W/ 1.42 60'
First pass was a 10.49@128.1 w/ a 1.46 60'. The temp was still dropping and my front end came up more than usual. I tightened up the front a bit, pulled the air cleaner out and waited for the air temps to drop a bit.
2nd pass was a 10.400@128.96 w/ a 1.42 60'. Every one of those numbers is a new personal best for me NA.
After that the temps kept dropping but the dew set in. I wanted a 10.3x but I spun on both passes. I could have left a little easier and hooked but I needed the best 60' possible to beat my best and that wouldn't have happened on a soft leave.
This is at the new Palm Beach International Raceway that used to be called Moroso Motorsports Park.
http://files.filefront.com/Bonnar+n+.../fileinfo.html
http://www.youtube.com/watch?v=jOXU8uqGimg
I had a chunked plug going into that pass and when the car came up it started walking out of the groove on me towards the center of the track, I had to ride the limiter down and then finished out the pass. I'm hoping for 9.teens. Converter needs to be tightened a little.
This car is a REAL daily driver. I drive it it atleast 15K miles a year and the way you see it making those passes is the way it sits in my driveway, tire pressure, pump gas and all. DVD,TV,Navigation, power everything, A/C, Heater, Subwoofer and Amp. Only thing missing inside are the rear seats.
Raceweight is about 3450-3500 w/ me in it.
I may gut the car Wednesday. It is supposed to be cold out during the day. The problem with PBIR is that once the sun goes down, the dew sets in and the nasty hook goes away. Cold air, day light and a little weight reduction should net me a 10.2X pass.
Thanks for the props!
All this time I had the wrong video posted. Here's the correct video for the 10.400 pass.
http://www.youtube.com/watch?v=p7snPVJ_vxE
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
Very nicely done, congrats!
Moroso is my old stomping grounds (dad still races there), and PBIR looks killer! Can't wait to check it out in March next year.
Derek
Derek
