Changing tach output to "normal" 8cyl output in HPT
Old 12-01-2008, 02:22 AM
ryanvv355's Avatar
Default Changing tach output to "normal" 8cyl output in HPT
I assume that you are adjusting the sin wave output from the computer using this area of HPT:
Does anyone know what numbers to put here to change from 4 cylinder output to 8 cylinder? Using my extraordinary keen electrical principles knowledge I would say put it at 12.
Or am I completely off my rocker?
Old 12-01-2008, 05:05 PM
7 Second Club
10sec_rx7's Avatar
its either 12 or 15 from memory
Old 12-02-2008, 08:39 AM
y2khawk's Avatar
3 and 3, you want to double the output not half it.
it's counting 24x pulses per high and low of the tach.
6 high and 6 low = 2x tach
3 high and 3 low = 4x tach
Old 12-02-2008, 10:30 AM
Aaron91RS's Avatar
Both 3's were too low and both 4's to high on my 3rdgen.
I ended up doing 4 and 3. It reads a couple hundred high at most at idle and when I step on it it gets even closer as the RPMS go up.
It would be nice if HPtuners made it so you could do decimals like 3.5
