355 Rebuild
355 Rebuild
Well after finding metal shavings in my oil and since my clutch is going out I decided to just let her sit and open up a new bank account solely for funding my car. First I planned on getting a pressure plate from autozone and a spec 3+ disk and breaking it in on my current motor for 500 miles so that clutch will be ready for the new motor.
I don't really have a power goal in mind for this. I suppose 400 rwhp would be a mark I would like to hit and don't think that it would be out of the question but I'd rather have something that makes power all over the board and not just peak numbers.
so far this is the list of parts I have come up with
fuel system:
racetronix fuel pump kit
delphi 42# injectors
rotating assembly:
stock crank
Eagle "ESP" forged h-beam connecting rods
Mahle forged pistons & rings
bearings:
main, cam, and rod bearings will all be coated Clevite
heads:
AI 200cc
arp head studs
cam:
custom grind from AI
valvetrain:
magnum NSA 1.6 roller rockers
guide plates
chromoly pushrods
arp rocker studs
ls7 lifters
intake:
professional products 58mm tb
ported intake
oil system:
new stock oil pump and pickup
timing chain:
cloyes double roller
misc:
keyed hub
gasket set
either street or dyno tune
do you guys see anything missing? if so what? and could anyone give me a ballpark est of what it cost them to rebuild their botom end in machine work?
oh and i'll be using non wear parts from this motor on my new motor like:headers, meziere water pump, etc
fuel system:
rotating assembly:
stock crank
bearings:
heads:
AI 200cc
arp head studs
cam:
valvetrain:
guide plates
chromoly pushrods
arp rocker studs
ls7 lifters
intake:
ported intake
oil system:
timing chain:
misc:
keyed hub
gasket set
depending on cam size you could be anywhere from 410-450rwhp. I would go with another TB tho, the professional products piece is made in china.
The spec stage 3 is a strong clutch, if you do any racing plan on picking up a new rear. I would go with at least a 3.90 gear, 4.10 or 4.30 depending on the plans for the car.
I would add some support to the mains if you ever plan on spraying the motor, or if it will see a lot of high rpm use.
Otherwise your build looks good.
Yeah, I would definately go ahead an add ARP Studs to the mains...otherwise everything looks pretty good.
You can get by with a smaller injector also, 36-37lbers will be more than enough.
your build looks alot like mine...but im going th350 since my car is auto..im hoping to hit mid 10's with 150 shot....outlawZ did it, thats where i got my set up from..so will see if i can hit the estimated ets i want
