How to clear codes on OBDII TA?
I've tried to clear the code on my '96 TA with no luck. Before, I could just pull the PCM IGN and PCM BATT fuses and leave them out for about 15 minutes and it would clear. Now, I can remove every fuse, disconnect the negative battery cable, turn on the light switch and the code still remains. Is there any way to clear the code I don't know about? My scan tool does not have a function to clear trouble codes. Thanks. MJD
