C6 motorspot wheels help?
I have a 2002 camaro with stock suspension. I am wanting to get the staggered form of the C6 motorsport wheels. Do I need a spacer for the back 19's? Do I also need to make any ride height adjustments? Any help would be much appreciated
http://www.wheelreplicas.com/c6mwheels.html
You will most definitly need a spacer. Im running a .5" but the general conscencus is to use a 1.25" hubcentric. I am going to run a 1" hubcentric, ive pounded my inner wells good enough that I dont have too much rubbing with the .5" but it could be a lot better. Im lowered, and its fine, if your stock ride height even better, but I would get tires to make the diameter the same as the fbody stock. I am running a C6 tire as well and its 1" bigger than stock.
