Stock 1/4 time for 96-97 ws6/SS
Old 12-02-2008, 12:09 PM
98Z28importslayer's Avatar
Default Stock 1/4 time for 96-97 ws6/SS
Whats the 1/4 time for a 96-97 ws6/SS M6 with just exhaust work ? also whats the downsides of a lt1 ws6/SS compaired to the ls1 ws6/SS?
Old 12-02-2008, 12:29 PM
impaled's Avatar
the LSX is the next generation of the SBC line. after the LTX
the LSX is a better engineered engine, doesnt have the finicky opti, the head design on the LSX's is superior flow-wise.
the only downfall is that IIRC the LSX's have aluminum blocks as opposed to iron like the LT1. i prefer an iron block. maybe just because thats all i have had, but the weight difference would be a positive, its just that iron takes heat bettter. the LS1's also have aluminum drive shafts which wont hold as much power as the LT1's but obviously have less rotating mass.
Old 12-02-2008, 12:49 PM
kinglt-1's Avatar
High 13's on street tires.
The ls1 is all around a more efficient motor, from the head design and the coil per cylinder ignition, to the composite intake, which helps keep intake temps down. Lt1's heatsoak bad in the warmer month's. Although when it comes down to modding the two motors, the playing field evens up a bit. Lt1's are alot cheaper to mod and respond well once the heads are worked! Ls1's are pricey to mod, but the prices are coming way down and the aftermarket is huge!
Old 12-02-2008, 01:06 PM
registered user
ScreaminRedZ's Avatar
I'd say the average time if probably around 13.9 for the WS6/SS.
As far as the 2 motors, they can both be made to go fast so I'd choose based on looks or pricing.
Old 12-02-2008, 01:16 PM
Dave 96TA's Avatar
They're capable of 13.8-13.9 stock on street tires, quicker on drag radials. Any variables are in the driver and the environment (altitude, weather, etc).
The LT1 has a great sound and responds well to mods.
The LS1 is easier to work on, work with, and find a tuner for. The LS1 cars also have better steering and brakes.
All the other things like suspension, squeaks, rattles, leaky seals, etc are all the same.
Old 12-02-2008, 01:51 PM
AChotrod's Avatar
With full exhaust low 13s maybe better are possible, I ran 13.32@103+ in my 96 ws6 on
Nov. 1st. with a cat back only and drag radials
I would not say this is the average but some are faster than others so it is possible!!
Old 12-02-2008, 02:04 PM
StealthFormula's Avatar
Stock I ran a 13.9 at 100mph in my auto in the summer heat with a 2.08-2.1 60'.
Assuming equal driving skill and conditions a stock LS1 WS6/SS is faster than a stock LT1 WS6/SS.
Old 12-02-2008, 02:09 PM
sdm1234's Avatar
My car, with just a full exhaust from headers to tips (no tune) went 13.9 @ 101
Old 12-02-2008, 03:09 PM
slp96ss's Avatar
the 96 ss with the performance exhaust (310 hp) was said in a magazine to do 13.46 sec. that is obviously with a very very good driver, but if it's possible, it's possible.
Old 12-02-2008, 03:17 PM
Trick450r's Avatar
maybe true but youll never see 310hp out of a stock lt1 with an exhaust.
Old 12-02-2008, 03:20 PM
SS Aleks's Avatar
When my 96 SS was stock it ran 13.5 @ 103. That is off the showroom floor.
Old 12-02-2008, 03:39 PM
brynnda's Avatar
from my experience having owned both an ls1 and my lt4 converted ws6 the ltx cars are more torqey off the line and the lsx cars have more top end pull. both are great motors, like everyone is saying ltx are cheaper to mod lsx more expensive but i feel lsx cars respond better when modded. mines deeply modded and im only hitting 12.9 on d/rs with a 1.6 60 ft and a .023 r/t, BUT that is with a stock cam, exhaust leak and bad tune, lol
Old 12-02-2008, 04:03 PM
slp96ss's Avatar
my car is rated at 310hp from the factory. obviously not 310hp at the wheels, but regardless, its rated at 310hp.
Old 12-02-2008, 05:21 PM
AChotrod's Avatar
I could swear that all LT1 SS's had the performance exhaust option and were rated at 305hp????
Old 12-02-2008, 05:33 PM
slp96ss's Avatar
nope 305hp w/o and 310hp w/ the exhaust. its called the totl or two on the left exhaust. looks stupid but sounds mean.
Old 12-02-2008, 05:51 PM
AChotrod's Avatar
I remember that exhaust just thought it was standard for an SS
Old 12-02-2008, 08:18 PM
96lt1m6's Avatar
the motor that is in my car was from a 97 TAws6 ramair which was 305hp sure was a pretty car till an f-250 ran into the pass rear wheel! was not my car but still another f-body done!
Old 12-02-2008, 09:44 PM
ElkySS's Avatar
id say its a tad quicker than you guys are saying. my bone stock 94 t/a m6 ran 13.7 with a 2.0 60ft. not even a ws6. granted i kinda thing my car was a factory freak when stock. also it had i think 85-90k miles on it.
Old 12-02-2008, 10:56 PM
tspence45's Avatar
I've seen where a magazine ran a 13.4 in a bone stock '96 SS. All the others I've seen range from 13.6-13.8. And we all know that magazine times aren't really exactly all that the car's capable of, except maybe the 13.4. I doubt a stock LT1 SS/WS6 is going to do any better than that on street tires. Most would probably range from mid to high 13's.
Old 12-03-2008, 06:07 AM
Rob
Rob's Avatar
My 96 WS6 Formula ran 13.5 the one time I had it to the track stock. That was back in 96. Then I put in a K&N, 160 t-stat, 4.10 gears, and HPP+ for the speedo and ran 13.18. Still on the stock GSC's.
Then the mods started
Quick Reply: Stock 1/4 time for 96-97 ws6/SS
