How BIG of a tire to Hook on the street?
How big of a tire and size should I get to hook on the street?Should I get drag radials or ET streets or Slicks?any input will be helpful all my mods are on my sig.
M/T DR, 275/50/15 would probably be best for the street. There are a lot of factors to hooking on the streetlike temperature, smoothness/type of pavement, and psi/temp of tire. But I would give the M/T a try, it doesn't get too much better than that for a radial.
Thanks man ill keep that in mind cuz im on M/T ET street radials and those are garbage.
yeah the 275/60 would be better. The 325's would be the best but you would have to do some work to you inner finder well.
275/50 = 26 X 11.50R15
275/60 = 28 X 11.50R15 *
325/50 = 28 X 13.50R15 *
Yeah i've been looking at the 275/60 = 28 X 11.50R15 on summit. Ima get them on friday.
hopefully you have the suspension needed to hook. tires are important but the suspension is just as big of a factor.
my car puts down 452rwhp and does not hook if i get agressive on the throttle in D with my M/Ts and I have a decent suspension. wish i would have gone with the qa1 coilover setup.
