235 trickflow on 6.0 iron block?
is this n/a. what do you see in the set ups that are bringing them close to the 600 mark besides the heads,is this common? is the exhaust and fast set up the deciding factor?
also, is it possible to run tfs235 on the 346 for awhile until you do the swap.i know it would be prob not be a good fit, but it must be better than stock heads for the time being. i would hate to throw on another 3gs on top of the engine swap for the heads alone.
Restricted User
also, is it possible to run tfs235 on the 346 for awhile until you do the swap.i know it would be prob not be a good fit, but it must be better than stock heads for the time being. i would hate to throw on another 3gs on top of the engine swap for the heads alone.[/quote]
346 is way too small for the 235 heads. 215's are better suited for that application. Or 225's for now if you are planning on running with the 346 for now then going bigger later.
let me know what all you put in there to make thqat kind of power. I am getting a 402 with those heads and pretty decent cam should be on the dyno today or tomorrow lokking forward to see what it will do. fast 92/92 also
These are definitely bigger cam FAST 92 deals with good headers and everything obviously.
