FAST flash programmer
http://www.fuelairspark.com/Products...ammer/over.asp
what are your guys' opinions on this? will i be able to adjust my spark and AF ratio's manually, (because i have a wideband to read off of)? im just looking for a cost effective way to adjust my bolt on car before i get a full dyno tune on H/C and spray...also will i be able to adjust my TC lock-up? im confused as to if it only includes the 3 options for flashes or if i can manually adjust and save my own tune...any experiences? thanks
found this:
Fast
Fast-Flash
3400 Democrat Road / Dept. GMHTP /
Memphis, TN 38118 901/260-3278 /
GAIN
HP:10.1
TQ: 15.4
PART NUMBER: 170382
PRICE: $320
SHIPS WITH: Instructions, cable,
two-tooth star connector cap
WARRANTY: 1 year (original
purchaser)
Main Menu
Performance tuning
DTCs
Engine data
It Can Adjust
DTCs
Speed limiter
Speedometer
Gear ratio
Trans shift points
Trans firmness
Power Enrichment level over
3500, +/-15% in 5% increments
Spark, +/-10%
Custom cams
Octane level
Fan thermostat
Included Tunes
Performance tune, performance tune 93 octane, three custom camshaft options
Notes
Medium-sized display, OK readability, no backlight, detailed engine data readouts
Driveability
Good
DYNO RESULTS
PERFORMANCE TUNE
TIMING: 24.5, 24.5
AIR/FUEL: 12.4, 12.4
RETARD, DEGREES: 0, 0
HP: 338.1, 339.1
TQ: 364.0, 364.4
PERFORMANCE TUNE 93 OCTANE
TIMING: 28.5, 25.5
AIR/FUEL: 12.7, 12.2-13.0
RETARD, DEGREES: 3.5, 0
HP: 337.4*, 336.3**
TQ: 364.2, 362.0**
Fast
Fast-Flash
GAIN
HP:10.1
TQ: 15.4
PART NUMBER: 170382
PRICE: $320
purchaser)
Main Menu
Performance tuning
DTCs
Engine data
It Can Adjust
DTCs
Speed limiter
Speedometer
Gear ratio
Trans shift points
Trans firmness
Spark, +/-10%
Custom cams
Octane level
Fan thermostat
Included Tunes
Notes
Driveability
Good
DYNO RESULTS
PERFORMANCE TUNE
TIMING: 24.5, 24.5
HP: 338.1, 339.1
TQ: 364.0, 364.4
TIMING: 28.5, 25.5
HP: 337.4*, 336.3**
TQ: 364.2, 362.0**
Actually heres the website, they compare a bunch of Handheld Tuners and compare to see which are better.
http://http://www.gmhightechperformance.com/tech/0805gmhtp_handheld_ls1_tuners_tuned_in/index.html
