About to install Watts Link... anyone have any advice?
LS1TECH Sponsor
Read the instructions carefully. Make sure you have the suspension loaded when you go to adjust the angle of the arms/clamps so they are level @ ride height. In fact it's best to actually measure the ride height as the car is most often driven (with driver, and whatever else that might be inside). Then make the car sit at the height as you setup the Watts link so you can get the angles exactly right for how the car is driven down the road...
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
