Going to a 3 bar MAP
Frost,
Is there a 3 bar that screws in. I like the cost on the GM unit you sell but am going to sell my fast 90 and go to the victor jr with the aaron elbow. I thought the screw in sensor would provide a cleaner more trouble free installation?
I will be pushing over 20PSI with the turbo system im installing this winter and am afraid to use the fast intake.
P.S. nice website I will be using it
Those MAP sensors don't fit a Corvette C5 manifold. I discoverd that when I took the manifold off. What you need is the MAP sensor from a soltice. The one at the top, not the one at the bottom. Check out other forums.
The photo is of a 2 bar sensor
When I found that the MAP sensor I had bought did not fit, I took the route you mention. There was already a 2 bar MAP for the fuel pump reference, so I hooked this into the CPU feed used by the 1 bar sensor whilst the manifold was out. A bit Heath Robinson but it works.
I understand, but the thread title is 3-bar MAP so I was pointing out to the poster that there is not one in the arrangement that was shown above.
What's Heath Robinson mean?
-nvrmnd http://en.wikipedia.org/wiki/Heath_Robinson
