Single Digit Club - 408 9's on motor. am i dreaming?
View Full Version : 408 9's on motor. am i dreaming?
TJ
12-03-2008, 08:27 PM
i know some light cars and some larger inch strokers are getting there pretty regular.
whats it gonna take at 3400# raceweight?
l92, ls6, tfs head hydro or solid roller?
car is sporting 5000 stall, 4.30 gear. will be single plane ported intake and 1000cfm carb. motor somewhere around 11.5-12.0 compression.
Bryan @ Speed Inc.
12-06-2008, 12:05 PM
TXCAMSS has done it pump gas, hydraulic roller w/ a 408 and some really good ported 5.3's i believe.
i think they're running a FAST intake too...
SIC LSX
12-10-2008, 05:58 PM
he got some heads alot better then l92's :) and a bad ass cam!!!!
krazy4
12-10-2008, 07:15 PM
Very, very possible.
Traction is the key :D
TJ
12-10-2008, 07:45 PM
i dont know about a lot better, but maybe more streetable.
SIC LSX
12-10-2008, 08:43 PM
you can run a way bigger/better cam with your new heads thats why they make so much more power ;)
L92's < Trick flow 235's :) TF you have alot more room to make more power ;)
racer7088
12-10-2008, 11:00 PM
Done several engines that run there but the car is what really needs to be there as well.
Krazy98Z28
12-11-2008, 06:36 AM
I'm at 3200lbs raceweight and had the wrong torque converter in my car and i almost saw 9s.
My goal for 2009 is 9.50 N/A.
SIC LSX
12-11-2008, 09:46 AM
he had a stock 6.0 block with stage 1 patriot ls6 heads flowed under 300cfm and a mid size cam and it was a high 10 sec car. His car works great!
94 guy
12-11-2008, 10:57 PM
krazy how did you get down to 3200lbs? pics of the car?
SIC LSX
12-12-2008, 01:47 AM
k-member/a-arms/Custom rack & pinion setup/front coil overs/Light ass weld magnums wheels/ light weight brakes and other basic interior mods. Here is tj's car
http://c3.ac-images.myspacecdn.com/images02/6/l_ad942089ccc44cb89e6a15943e0d9b6e.jpg
http://c2.ac-images.myspacecdn.com/images02/48/l_2d91bd5dae974628a930326aff9923d5.jpg
http://c3.ac-images.myspacecdn.com/images02/34/l_9cc19cfdab7d49a089198d20975ded0a.jpg
http://c4.ac-images.myspacecdn.com/images02/61/l_1763cc9c1406446fbeece670d51f62a3.jpg
http://c4.ac-images.myspacecdn.com/images02/62/l_b0bf71ca58e74ab0bfd61ff486b0a277.jpg
http://c3.ac-images.myspacecdn.com/images02/44/l_b45b982f348f40118e86e85bbb8b3a12.jpg
http://c1.ac-images.myspacecdn.com/images02/42/l_d90591cb93d5428695478cae8dcb188c.jpg
http://i69.photobucket.com/albums/i80/Dansredz28/freinds%20rides/6-1.jpg
Krazy98Z28
12-12-2008, 06:08 AM
Get rid of everything you don't need.
A/c
Heat
Power steering
radio/speakers
front bumper support
door bars
carpet
e brake handle and cables
cruise control
hood
windshield wipers and tank
both airbags
steering wheel
seats
seat belts
That's about it, I still have stock k member,brakes, abs.
Plus I only weigh 155lbs :)
http://i27.photobucket.com/albums/c177/Krazy98LS1/293.jpg
http://i27.photobucket.com/albums/c177/Krazy98LS1/Oct26_0005.jpg
http://i27.photobucket.com/albums/c177/Krazy98LS1/Oct26_0001.jpg
http://i27.photobucket.com/albums/c177/Krazy98LS1/DSC00973.jpg
Firehawk441
01-08-2009, 04:51 PM
I ran quite a few 9.8's @ 134-135 mph N/A with my old 402. Like racer7088 said, the car has to be able to run there as well. Good luck with your build.
TJ
01-08-2009, 09:35 PM
the more i look at it, the more im gonna be short. weight is going to hold me back for the most. part me, part car. haha.
got started on the shortblock today. hope to get some free time to get her finished up and in the car.
doing a cage now, so i wont have results as quick as hoped.
1badzo
01-12-2009, 08:38 PM
Yep your dreaming lol! I think you can get close because your car works i am all in favor of solid roller tho.:D
TJ
01-12-2009, 08:59 PM
it might get a bigger stick before i go solid roller.
all depends on what its gonna weigh when i get done hacking.
the car is untouched, and actually has about 20-30 pounds of sound deadening in it. you know. street car. most of that is going to come out. what i can scrap out anyway.:bang:
Chris05ssTruck
01-17-2009, 08:56 PM
DRAG car lol!
I have faith.....
U know i'm around 100 pounds lighter than u right? Just throwin that out there lol.
NemeSS
01-26-2009, 07:18 PM
nice car,
it would be cool to see 9's n/a with a ls 3rd gen
im gonna have to go turbo to see those times in my 3rd gen
good luck :)
