WB o2 vs. NB o2 AFR....WTF!!
I have QTP headers, so the collectors will throw off the o2 readings some, I understand this, but after tuning the VE and MAF with a AEM WB and the gauge readout for the AFR pretty much matched the HP readout and the WB tune was real close, I bought two new NB's and re-enabled CL, using STFT's only because I thought I had the tune close, with the NB's, and scanning for MAF error percent it has been reading anywhere from ~positive 5 but mostly it's reading negative, and in the lower regions of the maf I have seen it scanning as much as negative ~15 or so....WTF is going on?, the exhaust has two high flow cats at about the mid point of the exhaust and they DO heat up and help, but the exhaust smells strong and I think rich, so are the WB scans that far rich and that much off that the NB's are reading I would say an avg. of negative 8 in the lower areas of the MAF?
Once you get out of the lower areas the numbers are much better, and the NB's are still reading negative, but the most I have seen them off is about 4, does anyone understan what's going on? and what can I rely on?
What table did you make the corrections to in order to get your LTFT's in line ?? Some people use the VE table--some the IFR table and some the MAF table--The VE table changes don't happen immediately--can take up to 100 miles--The IFR table is quicker but the MAF table happens immediately-
You would be pretty stupid to not reset LTFT after flashing in a new tune. And when that's done the changes are instant.
The guys that use Roadrunners for their real time tuning would be pretty disappointed if changes to the VE table took 100miles to come through wouldn't they.
The wideband could also be incorrect. I had an AEM wideband next to an Innovate LM-1 and the AEM was a full point off in certain parts but who is to say that my LM-1 isnt off as well??? Although I have compared my LM-1 to chassis dyno widebands and my LM-1 seems to be right within spec of the dyno readings. Just a thought for you to ponder on.
He is tuning to get his part throttle fuel trims in line--His concerns center around PT operation which must always be correct before moving on to any WOT tuning--
Tuning under 4000 RPM's and NOT at WOT---The ecm only uses the VE table as a reference point--It will compare the commanded fuel to the VE table and use a combination of the 2---Therefore--changes to the VE table at PT & under 4000 RPM's cannot happen immediately because the VE table does not directly affect the fueling at PT
Re-setting the fuel trims does NOT make them learn any faster
I would say it is about 50/50-- using the IFR table or the MAF table to make corrections--It is contraversial and you'll hear pro-cons from both sides---i prefer to use the MAF table for small corrections as the changes happen immediately and can be more accurate and specific--
Under 4k is not exclusive MAP. Rather the PCM will be exclusive MAF after 4k. Below 4k is MAF at steady throttle and MAP in the transients.
Your right, resetting doesn't make them learn any quicker. But what is the point on running previous trim data if you have just flashed a new tune in that will run different trims. If one is going to tune off trims its better to use STFT's and turn off LTFT's anyway. That way you don't have to worry about the learning and the logging software can create an average model for you anyway. There are no pros to tuning off IFR mate.. Its just a lazy way for hack tuners to get buy.
To the OP. If your confident that you have tuned it correctly with the WB to get fuelling accurate. Ignore the NB's. The way they operate is hardly precise and if you have a big exhaust it can wreak havoc with exhaust flow characteristics at idle. Alot of cars I tune with large cams simply wont idle well in CL. Stick it in OL and find an AFR its happy with and run with it.
the lm-1 is very accurate one of the most accurate i have used. listen to macca, sounds like he is frustrated but for all good cause....
hint- turn ltft off dial in ve with wb and just use stft once dialed in.
That means what it says; and if you "tune" people's cars by raping the injector table then that says enough about you. You don't need "tuning training" to understand why this is an incorrect approach to tuning. Almost every fuel-related function is based off of the base flow rate. When you lie there, you dick up every subsequent fueling computation.
I personally would never use the IFR table to change anything fuel related other than the Injector size itself. Why change that when you can change it directly with either the MAF if your running it or the VE if you are SD?
This is what I start of doing, I will turn closed loop off and set the MAF to fault to make the car run in SD. I will then tune all regions of the VE table and get my readings to within 1.5% afr error. Once this is accomplished I then reset the MAF to operate and I proceed to tuning the MAF table to get it within 1.5% as well in all reagion's of the table. Once that is done I will go off and do some idle tuning (which is irrelivant for now) Then I'll turn closed loop back on and let it do it's job. With this process I have never seen the LTFT exceed 3% unless altitude or weather conditions apply.
In 02WS6Freebird's case I think part of the problem may be the wideband. The AEM isnt a very precise wideband for tuning but will get you in the ballpark. What you can do is keep your car in closed loop but make the MAF fault then use your fuel trim's in the histogram to modify your low load portion's of the VE table. This should get your fuel trim's closer to 0 for you and more than likely the narrow band o2's are more accurate at 14.7 than your wideband is anyway's. After you do this turn your MAF back on and setup a custom histogram that calculates your fuel trim's in the MAF table. Now go out and log some data of low load driving and modify your MAF table accordingly as well. This will get your fuel trim's closer to 0 as well. By doing the VE table and the MAF table it takes out any "if" in the equation and should calculate correct fuel delivery. What Macca_779 said about the VCM referencing the VE and MAF (mostly references the MAF when enabled though) is correct. You want your VE table to be as accurate as possible so it will calculate the correct airflow and have the right data to compare to the MAF data.
Don't you think you are going a bit overboard ? No one is speaking about "raping "the IFR table--only making small corrections to get LTFT's in line--I don't care what you believe or how you tune---The basic fact is that 50% of all tuners use this table to make corrections to LTFT's whether you like it or not--this info came directly from EFILIVE---I personally use the MAF table because you can be more precise with it-
You say before that you leave large cammed cars CL. I guess you've never heard of overlap then and it inherently giving false lean AFR's at low RPM. This is why I tune OL for the bigger cammed cars and run them leaner as they are getting more fuel during combustion than what the O2 sensor is saying. Better stability is a bonus and your not wasting fuel.
You say that you leave the VE alone and only tune off the MAF. I hope you run exclusive MAF then as if you honestly believe that the SD Model is largely ignore below 4k your dead wrong.
Here is the description straight from B0120
If engine speed is less than this value (4000rpm), then the PCM uses a dynamically calculated airflow value to determine grams of air per cylinder.
While the airflow is in a "steady state", then a correction factor is updated based on the airflow difference between the MAF sensed airflow and the MAP calculated airflow.
During rapid changes in airflow, the correction factor is applied to the airflow calculations to compensate.
If engine speed is above this value, then the PCM will use the MAF sensor exclusively (if not disabled by DTCs) to calculate grams of air per cylinder.
No updates are made to the airflow correction factor.
Tuning via adulterating IFRs is for "tuners" that need to learn how to tune correctly and look up a bit more about how the PCM works within itself and how data is referenced.
The only time the IFR table should be ever changed is if larger/smaller injectors are added or a manifold FPR is added and then flat lined.
Jez
Jez
As I've said in the past, you should be banned for shear stupidity.
LS1 Tech Administrator
Here's my 2 cents. Fresh narrow band O2 sensors that are fully warmed up are much more accurate to use for tuning when chasing stoich in idle and part throttle tuning. They are much more accurate than WB sensors. This is why the factory uses them. The problem occurs when using NB sensors with long tube headers and no cats. It takes much longer for the NB sensors to give their most accurate readings and they are not to be trusted until there's plenty of heat in the headers and the sensors.
Once fully warmed up, if you're still seeing larger than 2-3 percent swings in STFT, then further tweaks of the VE table are needed. I would NEVER jack with IFR for STFT or LTFT tuning. It affects too many other tables. You'll wind up chasing your tail.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
LAUGHIN MY *** OFF!!!!
Patrick
NB sensors are used because they are cheep and do a good but with finding 14.7 or there about. Your are correct that they must be warm. A wide band has heaters in its O2 sensor. That is why it is better with long tubes.
I can't say that a NB sensor is cheaper than a WB. That seems like flawed logic to me. There isn't really a price differential. But, a WB "works better" because it is an active oxygen pump cell. Some have a heater designed for aftermarket applications in mind. Stock narrow band is designed for a smaller heater because they know there is going to be a cat close to the engine and it won't need a bigger heater.
NB sensors are nice because of the mathematical algorithms that the PCM does on them and the weighted averages. This math is designed for the target of 14.7 for emissions. This part is COMPLETELY the fault of how the PCM is programmed to handle the NB O2 sensors. I think you can find that NB sensors are a narrow band; not a point measurement. (They are not good for one ratio only. They can handle from about 15.3 to about 14.)
There is some data out there on NB sensors and I am really sure the error on them doesn't instantly go to 100% as you deviate from unity lambda.
You can look at the cost of nb sensor vs wb sensor and see that the cost of the wb is 2X the cost of a NB. Then you have to look at the cost of the controller. It is 3 or 4 times more for a WB. System cost to an OEM is somewhere 2X to 3X for a wb. You can calulate this if you want.
As far as "NB sensors are nice because of the mathematical algorithms that the PCM does on them and the weighted averages. This math is designed for the target of 14.7 for emissions. This part is COMPLETELY the fault of how the PCM is programmed to handle the NB O2 sensors."
This is the same to the ECM. No advange to NB or WB. This is all about cost to the OEM. Eletronic hardware and warrenty. WB have more problems then NB.
I think NB sensor will go from 14.9 to about 14.4 at best. I know that they were designed to switched around 14.6 to 14.7. Once you move from here good luck with that.
I like poeple who think they know what they are talking about and treat that as fact. Have fun
