Fuel rail ends -6 or -8??
Looking at getting some fittings ordered for another project and thought I would order my fuel rail fittings as well. What size are you guys running? All the aftermarket rails are for 3/8 I just need to know 3/8 to 6 or 8 for the fuel line in and also for the crossover line. If I am thinking correct it is -8 for the in line and -6 for a crossover line or does it even matter?? Thanks guys. Also, if it matters I will be using the aftermarket quick connect to factory feed line.
I'd swap it out in high power applications. Right now I'm over 500rwhp on the stock system with a Racetronix pump. Currently working on the Lonnies/Racetronix double pump setup with -8an feed line and return type regulator using the stock feed as the return line.
Sorry if I came across like I was saying all cars should be done this way. I just assumed if people are running aftermarket rails they are shooting for big numbers, and forgot about the bling factor.
Not a bling factor in my case but also not real big power. Going NA but if I get the Fast intake or Fibertuned intake I will not use the factory rails due to I sold them with the L76 intake so I need new rails regardless and just want to know what needs to be done. Would you use a -6 feed in any case or use all -8's? Thanks for the help it is very useful.
Also be careful not all rails are 3/8" pipe some rails are -8 into the rail like ours. And if using the factory feed -6 is more then enough. Depending on your power level you do not need to go to a return line setup.
Nate
Nate
