9" u-joint
Old 12-04-2008, 08:57 PM
nealws6's Avatar
Default 9" u-joint
Anyone know the Autozone part# for a u-joint that fits the ls1 driveshaft and 9" rear? what gear oil should I go with and how many quarts.(runing a spool) THANKS for any info.
Old 12-05-2008, 03:09 AM
LS1>girlfriend's Avatar
stock aluminum driveshafts have a 1310 series yoke on both sides, so if your 9 inch has a 1310 series pinion yoke just get a stock u-joint.
you'll have to tell us what series yoke is on the rear end for anyone to help.
Old 12-05-2008, 06:32 AM
the_merv's Avatar
I believe the Steel one is a 1310 Joint, and the Aluminum one is a 1330 Joint, I know the Aluminum one is a little bigger.
I have an Aluminum Driveshaft and a Moser 9" with a 1350 Yoke, I used this U-joint..
NAPA #447 U-JOINT
Old 12-05-2008, 01:23 PM
nealws6's Avatar
have the stock 9" yoke with stock ls1 aluminum dirveshaft
Old 12-05-2008, 01:28 PM
the_merv's Avatar
I don't know what a Stock 9" Yoke is for sure, but I would think it would be a 1350 Series Joint, most of them are.
If it is, then the U-Joint that I posted up there will be the one to use.
If someone else has some info, feel free to chime in.
