gm847??
Old 12-04-2008, 09:29 PM
1badboo's Avatar
Default gm847??
Where can I purchase the gm847 cam? Also will this cam work on a stock lt1? I was planning on staggering the rockers with 1.6 and 1.5 new push rods and springs. Will I be alright?????
Old 12-04-2008, 09:47 PM
Taubr Unit's Avatar
theres like 3 recent post bout this cam.....
go back and scroll down and read them.
Old 12-04-2008, 09:48 PM
sz282's Avatar
Not the best choice for a stock motor
Old 12-04-2008, 09:59 PM
1badboo's Avatar
if you dnt want to answer the ? then don't reply to it.
Old 12-04-2008, 10:21 PM
-DIABLO-'s Avatar
u can buy it at summit racing for 259 and im trying to figure out my self if it would work on stock heads im thinking of going with cc306 its bigger than the cc503 but smaler than 847 and it sounds similar
Old 12-04-2008, 10:28 PM
1badboo's Avatar
thanks man... Yea I talked to a guy who buids them all the time just now and he said that it would be fine with stock heads but the more upgrades the better. I am going to use 1.6 and 1.5 rockers he said that makes the cam act bigger than what it is.....
Old 12-04-2008, 10:32 PM
-DIABLO-'s Avatar
hey ho did u talk 2 i bought the cc503 at summit cause i heard that 847 was to big so if ur right im gonna xchange to 847
Old 12-04-2008, 11:15 PM
1badboo's Avatar
His name is toby cunningham. He builds kenny ruckers promod motors but he does alot of street car stuff. Just to make sure though do you have the specs on that cam
Old 12-04-2008, 11:36 PM
97LT1's Avatar
If you had used the search, you would have found a lot more info. Your car is going to need better heads to go with that cam to not act like ****. Why would you put 1.6 with cam, when the heads will already be choking the motor? I say wait or go with cc306, or even better would be custom.
Old 12-04-2008, 11:48 PM
1badboo's Avatar
well guess what once again I didn't use the search so if that bothers you so much then don't hit the reply button.....
Old 12-05-2008, 12:01 AM
97LT1's Avatar
Ok buddy have fun with the wrong selection of parts. I was trying to be helpful but your too much of a tool to be aware of that, or just wanna be told the cam will work great.
Old 12-05-2008, 12:10 AM
LSWHO's Avatar
Stop perpetuating false information or show proof of this.
I've shown proof of stock bottom end stock heads 847 car running 11s with minimal other mods multiple times. I have as of yet to have someone show a single bit of proof on what you say and I've asked A LOT.
Old 12-05-2008, 12:29 AM
97LT1's Avatar
Cause everything I have researched on that cam on this very site and others, has said that is a big lift cam with upper rpm power production. High rpm needs heads that flow. Stock heads dont flow well in upper rpms with bigger cams. Everybody knows heads are what makes the engine, so why overcam the car if your heads are stock?
I dont have a dyno graph and hard info to display on a chart for you sorry. If you have been successful that is great, I have not heard much about anybody running 11's with cam only 847. Are you like a special case?
Old 12-05-2008, 12:46 AM
phirepower's Avatar
check out the stockheads/cam sticky at the top all your answers are there. It is sometimes difficult to locate this cam to buy
Old 12-05-2008, 12:55 AM
sweet-94z28's Avatar
You CAN run the GM847 on stock heads, but you just will not be maximizing the full potential of the cam and it will be much harder to tune. Here is a link to a flow chart with several LT1 head configuations on it. http://www.malcams.com/legacy/misc/headflow.htm
You will not need to stagger the rockers, but you can if you want to. The 847 is a high lift cam (1.5 rocker .539/.558 and 1.6 rocker .575/.595). I would run the 26918's (beehives) from comp.
This cam will work in your car, but I'll be honest, with the tuning aspect, you will make just as much if not more power with the CC306 cam. Its your car, do what you wish, but that is actually what I am considering for mine with ported heads. You just might find your car to be really stumbly, even with a spot on tune, till you get up in the power band.
Old 12-05-2008, 06:04 AM
Taubr Unit's Avatar
please dont PM me and tell me not to be a jerk. I "hit the reply" button to help you out and you can read all the info you want NOW instead of waiting for replys.
But go ahead and buy this cam....... along with the electric turbo to help it out and the whistleing muffler tip. TONS of HP there. Your car should really fly!
Old 12-05-2008, 08:04 AM
Goat2NV's Avatar
Why don't you just try the GM 846 cam, a buddy of mine turns some decent times with this cam and a 3200 stall, his stock heads are mildly ported though.
Old 12-05-2008, 09:35 AM
1redta's Avatar
Default re
1badboo you can do what you want, but these guys are trying to help you get your car running better. If you put in a 847/306 type cam, ported heads will only help you get your car running better, at the very least when you do the swap pull the heads and gasket match the intake and exhaust ports and the intake manifold. Good luck
Old 12-05-2008, 09:42 AM
1badboo's Avatar
thanks everybody for the info. I'm not upset at all. I asked for info and got it. It just seems that everybody has different info. I was just going to start with the cam and go from there. I understand that it will not run to full potential with this cam without head port etc. I just wanted to no if it would be drivabal for now with the 847. Maybe I will look at some other cams....
Thanks again
Old 12-05-2008, 09:44 AM
1badboo's Avatar
Thank you.
Quick Reply: gm847??
