prw shaft mount rockers?
Formerly darynC-10/23/10
im goin solid roller ima need adj rockers i was searching and i found these.
if you have any experience or know anyone with these rocker id appreciate some feedback . if you dont then no bias answers please, they are made from 6061 t6 which is better than crane or jesels 2024 .... hmmm???
http://www.prw-usa.com/shaftmountrockersystems.html
I use PRW's. There's a thread about it here somewhere. Anyway, mine are stud mounted, not shaft mounted like these. Only issue I had was the need to increase the underside rocker chamfer relief around the stud nut, some were hitting. You will not have this issue because the model you have shown are pedistal mounted rockers. Have had no operational problems & have pushed them hard both on the street & road course.
