Broke bolt off in head during valve spring install, HELP!!
So what methods for removal would you guys use for this situation.
The bolt that i was using for spring compression broke off...
Suggestions?!?
Suggestions?!?
id be scared to try it but maybe some lube to help ease whats stuck out while attempting to JB weld the head back on the bolt. Depends how much is sticking out and what im suggesting may not be the best but there you go.
How did it break? was it on THAT tight?!
Actually its 1 cyilnder back from the front, so its pretty accessable. But NONE of the bolt is sticking out above the head head.
I better NOT have to buy a new head, this sucks...
Heres what you can try and do. Take a small punch and a hammer, start by hammering the punch straight down on the top of the bolt. Do not punch straight into the center of the bolt do it to one side. What you want to create is a little divet for your punch to catch on. Now take your punch and angle it so that when you tap on it that it will be unthreading the bolt (counter clockwise). Just make sure you have a small enough punch with a good sharp tip. Think you could take a picture at all? Good luck I hope you dont have to pull the head.
yep id get a bolt extractor set . they evn suggest what size bit to use to drill the hole . then tap in the extractor and give her a few turns and out she comes should be pretty easy aslong as its accessable. i had to do the same thing w/ a broke manifold bolt during a header install .
gl man
gl man
left handed drill bit will be your friend if you use an easy out. just make sure the bit you use is the right size and doesnt damage the threads. also when you put the removal tool into the hole you drill dont use the drill to try and back it out. you want to start turning the removal tool nice and slow
