lt1 into a 1995 v6 camaro
Old 12-05-2008, 05:37 PM
armyguy_conn's Avatar
Default lt1 into a 1995 v6 camaro
I'm about to drop a lt1 into my donor 1995 camaro. I got the car for 200 and a cell phone. lol I was just wondering what all I need besides the Motor and Tranny. Help is greatly appreciated
Old 12-05-2008, 05:47 PM
cammed93TA's Avatar
https://ls1tech.com/forums/conversio...-t56-swap.html
good guy... he just did the swap...and did it very well I must add...
Old 12-05-2008, 08:50 PM
MonmouthCtyLS7's Avatar
Alot!!, try a search
Old 12-05-2008, 08:56 PM
jarretthise's Avatar
you will need to do a series of steps....pm me and i will give you pointers and stuff like that while you do what you do on your car..these cars are year specific and you cant just use anything when it comes to the harness and little stuff like that...just pm me and ill help you out as much as i can...ive done this swap twice so
Old 12-05-2008, 09:54 PM
the_merv's Avatar
Seems like it would be an easy swap.
Old 12-05-2008, 10:00 PM
sz282's Avatar
Seems like alot of work, but would be sweet if you can do it for pretty cheap.
Old 12-06-2008, 06:05 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I plan on doing the exact same thing pretty soon. My 95 is a V6 / A4 car. I have a whole bunch of extra LT1 parts laying around my garage. All I need at this point is an engine harness, PCM, Opti, set of heads, and gaskets. I'm going to use all of the front drive accessories off of my 93, engine out of a 96, A4 trans out of a 97, and eventually an OBD1 PCM and harness.
Old 12-07-2008, 07:23 PM
reaperracer666's Avatar
you need a derent kmember rear end transmission crossmember i belive torque arm bar pcm fuel pump gages theres probly more but cant remember try doing some searches they will help theres also sites out there with lists
Old 12-08-2008, 11:33 AM
Bad_tx_Z28's Avatar
it's not gonna be a problem for me, i have a 94 Z, and im buying a 94 V6. Im just gonna swap everything from my Z into the V6. I know its gonna be time comsuming. But if you have a parts car, it will be way easier!
Old 12-08-2008, 11:37 AM
z28rob18's Avatar
may i ask if you hav a 94z then y u swapping? did u wreck the car?
Old 12-08-2008, 01:37 PM
Bad_tx_Z28's Avatar
the car was wrecked when i bought it. I fixed the front clip well enought to get body panels and everything so i could drive it. Im getting this V6 fbody for cheap so im going to swap everything over. When my Z has everything out im going to completley redo the car.
Quick Reply: lt1 into a 1995 v6 camaro
