trick flow heads
Old 12-05-2008, 05:38 PM
formula4437's Avatar
Default trick flow heads
i am going to install the trick flow 515 hp kit this winter needed to know the supporting mods i will need. i know i will need a oil pump, timing set and injectors any thing else also any advise on chosing a oil pump, timing set and size of injectors already have the ls6 intake
Old 12-05-2008, 05:39 PM
link to the kit
http://store.summitracing.com/partde...0&autoview=sku
Old 12-05-2008, 06:02 PM
RJB01camaross's Avatar
LS2 timing set and oil pump will work fine. Injectors depends on your plans down the road but 36lb would cover you even with a small shot.
Old 12-06-2008, 09:23 PM
any other advise how about a fuel pump
Old 12-06-2008, 09:37 PM
peedeerooster's Avatar
I would go with the heads and a speced cam intead of the kit. You will make much better power and it will not cost anymore if you get a good shop to do it. Also, you will need to upgrade the intake. If you don't put a fast 92 on it, the intake will hold you back. I put the trickflow heads and VRX3 cam on my CTSV with the fast intake and I had to upgrade the injectors from the 28's. The 28 lb injectors held me back around 20 HP.
Old 12-10-2008, 08:56 PM
any more advise
Old 12-11-2008, 12:34 PM
sublime1996525's Avatar
I went with those heads milled to 59cc. Yella Terra Ultra Light rockers. Upgraded springs. Torquer 2 cam 112lsa. Melling high pressure oil pump. Fast 90/90 ported.
LS7 lifters and LS2 lifter trays. LS2 timing chain. And I think that's about it. Oh and a powerbond underdrive pulley. I should be getting it back today. Will post numbers when I get them.
Old 12-11-2008, 04:56 PM
shoot me your numbers
Old 12-11-2008, 06:04 PM
wilwhite2kss's Avatar
I had my kit milled to 61cc, sold the cam for a pat g, used a 92/92 , melling oil pump, walbro fuel pump, 42lb injectors, ls2 t chain, and will be getting a new clutch and tune soon. No numbers yet.
Old 12-11-2008, 10:26 PM
I just got the car back. 457rwhp and 400rwtq. I think it'd be a bit higher but was getting valve float at 6600rpm's. Oh well I'm still really happy. Thank you Cj and Ryne @ Cunningham Motorsports.
Old 12-11-2008, 11:35 PM
Spd-Kilz's Avatar
I've been looking into this package, except with a different camshaft than you choose.
Did you happen to get different valve springs?
Also, who milled the heads?
Old 12-12-2008, 08:44 AM
Dragkid1917's Avatar
Formula... I agree with everyone else as well. The TFS 215's, especially when worked over are nnnnasty heads. The cam isnt bad, but theres definatly 20 or so horses to be picked up by a bigger one. I would choose a different cam.
Old 12-12-2008, 10:06 AM
1.8t's Avatar
What are the specs on your cam and what valvesprings are you running. I would think valve float should be a non-issue at only 6600rpm with a properly setup valvetrain and a quality spring.
Old 12-12-2008, 12:05 PM
The cam is a comp cams 232/234 595/598 112lsa. The springs are good up to a .650 lift. I wouldn't have thought valve float would've been an issue. I was told that shimming the springs should take care of the issue. Any ideas?
Old 12-12-2008, 12:09 PM
I did get different springs. They are good up to a .650 lift and the heads were milled by Total Engine Airflow.
Old 12-12-2008, 06:17 PM
CoopZ06's Avatar
I went with a similiar package developed by Ron at Vengance Racing. My cam is much larger 247/251 .623/.623 113+3, but this is a drag only car. Short block will be back next week and should have dyno numbers shortly after the first of the year.
CoopZ06
Old 12-12-2008, 08:13 PM
SOMbitch's Avatar
A little more cam and don't forget the aftermarket RR's that should be run w/those heads if they are not in the kit.
Old 12-13-2008, 10:12 AM
The kit comes with harland sharp 1.7 rollers , so he should be covered with that. Also , just to let him know , i also went with a wallbro fuel pump as well. Im not sure if the stocker can handle that much.
Old 12-13-2008, 03:56 PM
ive heard the stock fuel pump should be good for now but a defenate for the future also any recomendations on a cam
Old 12-27-2008, 09:26 PM
would the torquer v2 cam be a good choice
Quick Reply: trick flow heads
