LS1 head question
Old 12-06-2008, 12:03 PM
95_ls's Avatar
Default LS1 head question
With me putting a 224/224 cam in my car how bad will my stock heads hold me back should i consider porting
Old 12-07-2008, 09:40 AM
MrDavid's Avatar
Hold you back from what? That all depends on what kind of power goals you are looking for. If you're looking for over 400rwhp, then yes, stock unported heads will hold you back.
Old 12-07-2008, 10:04 AM
gts500's Avatar
224 is ideal for stock ,i used it before and after heads swap not big diffrent ,hold on to your stock heads unless you goin bigger cams
Old 12-07-2008, 05:53 PM
MrDavid's Avatar
Not entirely true. There was a guy at G12 this year in Atlanta who had a 224 cam in his SS, and he paired it with Patriot Stage II 5.3L heads and had dyno sheets for 429rwhp. He also had all other supporting bolt'on mods as well. That was impressive to me.
Old 12-07-2008, 07:01 PM
95_ls's Avatar
[QUOTE=2K1WS6TA;10615189]Hold you back from what? That all depends on what kind of power goals you are looking for. If you're looking for over 400rwhp, then yes, stock unported heads will hold you back.[/QUOTE
I think i actually bought this cam off of u lol but ne way im looking to get around 375-400 right now with the stock 10 bolt i cnt go crazy. i was jw what kind of gains i could get by porting or swaping out heads
Old 12-08-2008, 04:18 AM
MrDavid's Avatar
If you got it from me, then you have a good cam. My car put down 390 on a speed density tune with all the regular bolt'ons and a heavily ported throttle body. If you have someone port your 241 heads, then you can expect to pick up some decent hp. If you swap heads to something CNC'ed with a slightly smaller combustion chamber, then you will see some very nice gains.
Old 12-08-2008, 07:59 AM
95_ls's Avatar
Sweet 390 sounds good to me. Heads proly wnt happen unitl the summer wen i actually have money lol
Old 12-08-2008, 08:04 AM
gts500's Avatar
its impressive for me , i combined the cam with Dart 205 and i end up with 380hp ? ( A4 )
impossible is nothing with moding ...
Old 12-08-2008, 08:27 AM
95_ls's Avatar
Did u have that dyno tuned??
Old 12-08-2008, 09:09 AM
RyanM02's Avatar
Holy hell man. Thats not right ?
hmmm. That just seems a little low.
Old 12-08-2008, 09:35 AM
the_merv's Avatar
You should be fine with the Stock Heads, unless you plan on going all-out, then I would look into a different Cam.
Old 12-08-2008, 09:44 AM
87silverbullet's Avatar
Yeah dude you need to look at your tune or something else is throwing off your numbers. I had a TR224 with MTI (houston) stg2e heads which aint much of a port job on them and I put down 405 rwhp thru an auto.
Old 12-08-2008, 02:01 PM
gts500's Avatar
its ok that was before..now i have diffrent mod . (in the sig)
i think because am spraying 150 shot the tuner had to lower the number a bit
applying less spark advance and richer fuel .
but its all diffrent now the car is a beast after the latest modding .
(sorry 95_ls i didnt mean to hijack the thread ) its not my intention just trying to help
Old 12-08-2008, 04:00 PM
95_ls's Avatar
It's cool man im just glad u got that **** running right
Old 12-09-2008, 09:06 AM
gts500's Avatar
INDEED
mony + time + pain + = smoke every one
i hope you get your car done right too man , good luck .
