New ZR1 Differential Fits in the C5 !!!
Here are some pictures of the new Z06 Diff (left) compared to the new ZR1 (right)
It looks to be quite a bit stronger :rofl: Looking at the last picture, the cast is thicker inside and out !
If you wanted to use this diff, it would require you simply bolt up a c6 rear subframe in your c5. Direct bolt on baby. I LOVE CHEVROLET
About 4K
Correct, you would need the rear sub frame, lower controll arms, put the complete T60 trans and diff in the car. You could also have the 32 spline tranny shaft installed in your T56 and have your pinion re-splined to utilize the larger shaft. All bolt on GM parts, no cutting, banging, or smashing required
Do it once, do it right the first time !
I believe the case has a different bolt pattern.
