Injector offset
Injector offset
Trying to find a injector offset table for 30# SVO ford injectors and also pulse width settings. Have searched and can't find were any tuning files were these have been changed. I have read were this tables need to be also changed when putting in larger injectors. If any one has a file with these changes would much like to see it. thanks Bill
Try Yahoo!....seriously. That's where I found 'em. Only problem is, Ford uses a high/low offset kind of setup and the voltages don't exactly line up perfect. But, you can get close.
