1990 corvette ecu problems
Old 12-06-2008, 08:46 PM
perrco's Avatar
Default 1990 corvette ecu problems
ok so my freind got a 1990 corvette and the guys said the computer was fried so we put a new ecu in it but it wont fire. we tryed to reset the security with this key method we found. any ideas
Old 12-06-2008, 09:41 PM
poconojoe's Avatar
How did they decide the ECM was bad.
Does it crank?
Did you use noid lights to check for injector pulse?
Does it run a few seconds and stop?
Did you measure the pellet resistance and put an resister in to replace it in the harness?
Old 12-06-2008, 10:39 PM
perrco's Avatar
the guy he got the car from said it was bad and had a new one just never put it in
Old 12-07-2008, 12:45 AM
wrencher
wrencher's Avatar
Central timer modules (BCM) go bad in those too. Have to do some testing & see.
Those will get the security light going too.
Old 12-07-2008, 07:15 AM
poconojoe's Avatar
90 vette should not have a BCM, they were TPI motors, that used a VATS module to operate the the anti-theft on the starter and the ECM
Old 12-10-2008, 07:40 PM
perrco's Avatar
ok we started messing with it and it will it will turn over but wont start when u roll the windows down will turning the key. its not firing and the fuel pump wont turn on
Old 12-10-2008, 08:41 PM
89 formula350's Avatar
is the correct prom chip in the computer?
Old 12-10-2008, 10:09 PM
perrco's Avatar
yes it. but if it goes bad will it cuase it to do that
Old 12-10-2008, 10:15 PM
poconojoe's Avatar
Did you check for pulses with noid lights on the injector plugs?
Old 12-10-2008, 10:17 PM
perrco's Avatar
how do u do that. srry still trying to learn this crap.
Old 12-11-2008, 10:37 AM
poconojoe's Avatar
Noid lights are little plastic plugs with an LED in them, that tells you if the injector is getting a fire pulse, when you plug them in to the injector plug. If you have a Harbour Freight near you, you should be able to buy a set for $20, if its a VATS issue there will be no injection pulse. Did you check the fuel pressure? We all have to learn sometime
Old 12-11-2008, 08:45 PM
yes it would but I can tell you I have NEVER seen one go bad just missing when ecms get swaped out.
Old 12-12-2008, 04:04 PM
Old Geezer's Avatar
"but wont start when u roll the windows down will turning the key."
Huh??????
Old 12-12-2008, 06:48 PM
perrco's Avatar
ok it will only turn over when u hit the window button while u turn the key. but it still wont start.
we still cant figure it out
Old 12-12-2008, 09:41 PM
Old Geezer's Avatar
Default Before..
you condem the ECM, I'd be looking at some wiring diagrams, and see how there may be a connection to the power window circuit.
There's likely some interface that powers the window circuit only when the key is in the on position??
Windows work w/ key in run position?
Windows work w/ key off?
A trip to the Vette forum may be in order....
Quick Reply: 1990 corvette ecu problems
