SubFrame
SubFrame
Can anybody show me some pics of there weld in subrfame connectors that are boxed that are on there car? Thanks i searched but found hardly nothing that i wanted
http://www.umiperformance.com/2000?category_id=129
At the bottom of the screen they have several pics of what you are wanting.
If you dont want to worry about clearance or anything else you could also look upon the bolt in subframe connectors from UMIhttp://umiperformance.com/2002?category_id=129) I put em on and inmediatly felt the difference; then I drove and got them welded. Either you go tubular or boxed you will feel your car very sturdy..
Hello,
None of the SFC's we offer will reduce ground clearance on your vehicle
And since you have ground effects on the side of your vehicle none of our SFC's will even be able to be seen from the side.
If you are looking for the tightest fitting set our tubular 2-Point designs tuck tight against the floor of the vehicle. Part # 2001 and 2002, 2002 is a 100% bolt on set-up that requires no cutting, grinding or drilling and can be installed in 20 minutes.
www.umiperformance.com/2001
www.umiperformance.com/2002
If you have any questions please ask. thank you!
Ryan
Ryan
Hope that helps!
Ryan
Ryan,
Thanks for the quick response. I would be doing it on a jack, so I will plan on more time. I just changed out the LCA's so the bolts shouldn't be too much of a problem. Thanks again!
yep thats all i needed guys. just getting my suspension done first before i put all my motor and stuff in. I ordered adj. panhard and adj. lower control arms the other day. this is next
