42's or 60's for 427 NA build?
Like the title says which would be better for my setup? Solid roller with TFS 245's and most likely a Fast 92 setup. Been told 42's before but the more I search the more it looks like 42's won't be enough or be right at the edge. Thanks for the help.
Here is a quick calculation based on 675 FWHP N/A. I'm not sure what kind of power or RPM your shooting for but if you make more than 675 FWHP you will be close to 80% duty cycle by using 42 lb/hr @ 3 bar injectors. They will fuel the motor but do not offer much room for more power in the future.
Calculation:
Calculation:
