Goodyear F1 GS-D3 questions & help needed
Old 12-07-2008, 09:49 PM
mike13's Avatar
Default Goodyear F1 GS-D3 questions & help needed
I have a set of GS-D3's 275/40-17 on my 1999 Firehawk, they're a little unsettling the way they pull and follow ruts, the best way to describe it is the car feels twitchy. Is this normal? No unusual wear or other problems, car only has 38k miles, steering is tight.
Old 12-07-2008, 10:12 PM
jmilz28's Avatar
What are your alignment specs?
Old 12-07-2008, 10:31 PM
mike13's Avatar
I don't know.
Old 12-07-2008, 10:41 PM
mike13's Avatar
Also what tire pressures are you running?
Old 12-08-2008, 12:06 AM
kidcamaro98's Avatar
I have the same tires...315's in the rear also on 11" wide TTM's....mine does the same damn thing. I have 40psi of pressure in all 4.
Old 12-08-2008, 12:09 AM
jhatler2002's Avatar
More than likely it needs to be aligned, but for starters check the tire pressure. This happened on my dad's formula and one of the front tires was just a little low and when I aired it up it fixed the problem.
Old 12-08-2008, 04:20 AM
SSmokin99's Avatar
40psi, seems like a lot. I have these tires in 275/40/17 and I have 30-32psi in them. I'm VERY satisfied with the tires too.
Old 12-08-2008, 08:43 AM
RsSean's Avatar
Yeah I will have to agree that 40 is way to high. I have the GS-D3 275 in the front and run 33 and 315 same tire and 35. Pulling is just cause they are so wide. Mine does the same thing pulls like it wants to go in the wall. My alignment is just check and I was the one that did it.
Old 12-08-2008, 08:46 AM
Xsta Z 28's Avatar
Check tire PSI, if the PSI is too high or too low the tire will act "funny" over the road irregularities.
alright I will lower my PSI then...maybe thats why I cant hook up worth a damn even with my torque arm and LCA's.
Old 12-08-2008, 09:19 AM
NC01TA's Avatar
Another agreement about 40 psi being too high. These tires will be all over the road and you will 'feel' everything.
Old 12-08-2008, 11:53 AM
great421's Avatar
Default 9.5 rims still too small for MY LT1/4 NA!!!
The Goodyear shop here in Greensboro put 45 psi in mine! After i dropped it to 34 everything was fine - though I still can't hook with those 275's in the rear though - If the vette 10 spokes came in an 11" width, I'd be all over those!
Old 12-08-2008, 02:08 PM
dont worry about it...I got 315's on the rear of mine with a spohn torque arm and bmr lca's and I spin all of 1st and 2nd
Old 12-08-2008, 07:21 PM
slim0035's Avatar
I had a set a couple years back, unable to afford them again since, but I ran 30-35 psi in them. The directional tread and the width of the tires are what causes it to "follow" ANY rut in the road. Scared the hell out of me the first time it happened at speed. You just have to get used to it and change your driving to anticipate it. Not easily done, you just have to be able to do it unconsciously.
Old 12-08-2008, 07:24 PM
RareBreed0295's Avatar
Had the 275s on my car and they always pulled bad. Especially driving in the rain.
Old 12-08-2008, 08:41 PM
mike13's Avatar
When you get the car out on some good roads they work and drive great it's that beat up rutted intersate that pulls the car. Also I don't know about other states but in Washington the interstates have a seam about a foot inside the lane marker.
