Power/ET predictions?
Old 12-08-2008, 10:31 AM
tomcowle's Avatar
Default Power/ET predictions?
3000lb (with driver) F-body, all good suspension parts
Turbo 350 or PG with 5000k stall
4.33 gears
28x10.5 s mt slicks
LQ4 shortblock, rehoned and fitted new zgs rings, bearings and rod bolts
Ported 5.3 heads 300/200 cfm milled 20 thou
234/234 613/613 on 107 Cam
Victor jr carb intake, built 750dp
1 3/4" lt's with 3" collectors
What kind of power is here and what do you think about the rear gear?
Any ET predictions?
Old 12-08-2008, 11:24 AM
TJ
TJ's Avatar
my setup is VERY close to yours.
same gear, stall, shortblock/heads
vic jr(PORTED) 750hp
3400# raceweight.
cam is 235 237 599 602 112+2
times in sig.
Old 12-08-2008, 01:14 PM
tomcowle's Avatar
Any thoughts about lowering your lobe sep?
Old 12-08-2008, 03:13 PM
TJ
TJ's Avatar
YES.
the motor is comming out. im building a new setup.
i went with that lsa based on the cam specs and stock motor.
valve reliefs/flycut, im sure it would make a lil bit more power.
