rim question backspacing
Old 12-08-2008, 05:48 PM
mike2244's Avatar
Default rim question backspacing
centerline makes a telstar 15x10 with a 7 inch backspacing. has anybody tried this wheel and will it fit? i know i read that 15x10 requires 7.5 inches of back spacing, but if i'm correct the wheels will just stick out 1/2 inch further. they should still fit without any problems?
Old 12-08-2008, 05:53 PM
phantomLT1's Avatar
What size tire you runnin
Old 12-08-2008, 05:56 PM
leadfoot4's Avatar
I thought everybody had caliper clearance issues with 15" wheels??
Old 12-08-2008, 06:03 PM
phantomLT1's Avatar
YEP be prepared to do some grinding OP
Old 12-08-2008, 06:04 PM
mike2244's Avatar
i don't know what size tire yet, i want to buy these but i want to make sure that i am not making a mistake. it really don't matter what size tires because these are going to be my street wheels and whatever tires i go with there not going to give me enough traction to make my rear squat that low to rub the tires. my slicks are mounted on other wheels.
Old 12-08-2008, 06:06 PM
mike2244's Avatar
i have been told that the 15x8 telstars fit with out grinding, with the LT1 brakes. why would the 15x10 rub the calipers
Old 12-09-2008, 07:30 AM
leadfoot4's Avatar
I don't know first hand, but from what I've read here, I believe it's a question of rim diameter, and possibly the shape of the backside of the rim's center, not rim width that is the problem...
Quick Reply: rim question backspacing
