355 or 383
Old 12-08-2008, 10:15 PM
ale76051's Avatar
Default 355 or 383
This winter i am planning to start to build a new motor for my 96 Formula M6. the main reason for the build is coming up next august im going to be livin in germany near the autobahn to really test the car, but also my engine now has 129,000 hard miles on it. i have come to two different options which i dont no which to choose: a blown 355 or a fully built 383. does anyone know of any advantages of each or which one might be better for a "weekend warrior"?
Thanks for any advice you may have, Adam
Old 12-09-2008, 01:18 AM
In-Zane Moderator
ZONES89RS's Avatar
Uhhh...blown 383...and dont look back. Blown 396 if you want everything you can get out of it.
Old 12-09-2008, 01:45 AM
transamws6_97's Avatar
im not sure how you are comparing a blown 355 to a built 383? too many variables. i would still go forged 355 if you are gonna put any serious boost on it. in that case a built 383 will be basically the same in cost as a 355 minus a lil extra machine work for the 383. in that case you are also spending more for a better fuel system to feed the blower, and the blower will also add another 5-6k on top of your build cost. there are just too many variables to say
Old 12-09-2008, 03:19 AM
bombebomb's Avatar
From that, a blown 355. That "built" 383 wont be able to touch it unless you have a monster cam/heads, and most likely still will not touch it.
Old 12-09-2008, 06:46 AM
ryle's Avatar
+1 for Blown 383
Old 12-09-2008, 07:16 AM
wrd1972's Avatar
The decision should be to blow, or not to blow.
355 and 383 will make similar HP, but the 383 will make more usable torque and cost more do to additional machining and upgraded components like better than stock heads.
I have a 355 and have no regrets.
Old 12-09-2008, 08:22 AM
Mattsz28's Avatar
Comparing a blower car to a NA car isnt really fair.
I built a 383, with a "monster heads and cam" package, and a nice big shot is in her future. On motor, the blower car is going to pull on a simple NA 383. Shot vs Blower, then its a fair game.
The bottom line is, its cheaper to build a NA motor and spray it. Until you break it ;-)
Old 12-09-2008, 11:19 AM
LM97Z's Avatar
Even if its blown, it still needs to be built strong to handle the load, when building anything, if funds are there, go as BIG as you can on the cubes, no substitute for cubic inches, then add what you want.
Old 12-10-2008, 09:06 AM
whammer33024's Avatar
i love not having to ask a question and pretty much have them answered for me anyway, lol. wrd1972...you're probably going to be getting some pm's from me in the next few months, lol
Old 12-10-2008, 09:59 AM
Racin96ss's Avatar
Figure out blower or NA first then make your choice between 355 or 383. 383 w/blower would work well also.
Old 12-10-2008, 10:07 AM
99 Black Bird T/A's Avatar
Received 1,431 Likes on 991 Posts
If your going to build a blown 355...I'd think you'll go forged...so you'll need forged pistons, forged crank and new rod's right? Might as well build a 383 for the blower motor since you'll likely want a forged bottom end on that 355.
Old 12-10-2008, 07:34 PM
Built LT1's Avatar
I would definatey go with 383 cubes rather than 355.
Old 12-10-2008, 07:48 PM
texas94z's Avatar
My vote is a forged 355 using stock crank with nitrous. FI and stroking = lots of money. However, if money isnt a huge concern build a NA soild roller 383.
Old 12-10-2008, 10:39 PM
slomarao's Avatar
blown 383 all day.
Old 12-11-2008, 08:17 AM
koolaid_kid's Avatar
If you first take the blower out of it, consider this:
A 383 will have longer rods, therefore it will produce more torque than the 355. A 355 will rev quicker and higher than the 383 because of the shorter stroke. Both engines will need to be forged. Depending on whether you select a 5.7" rod or a 6.0" rod, the 383 may require more machining ($$) to accomodate the longer stroke.
A F/I 355 will always beat a N/A 383, just basic physics of how F/I works. It will also be more expensive due to all the extra parts it will require. And the F/I will have to be sized to the volume of the engine; in my case, I would need a larger turbo if I went 383. In your case, you would need a different supercharger, say P-1SC vs. D-1SC (if you went Procharger). This is assuming, of course, that you went with a supercharger, which is the F/I that works best with your M6.
Old 12-11-2008, 08:21 AM
Javier97Z28's Avatar
More than half the people that build "blown" cars end up with shitpoor slugs. They don't take the time to tune 'em and get pushed around by N/A cars day in day out. I've seen more than I can keep count.
Building a boost car takes time, dedication, and most important... $$$.
That being said, my 355 has served me well.
Quick Reply: 355 or 383
