kaptainkw
12-08-2008, 11:43 PM
Howdy guys:
I have an '06 GTO LS2 with only 600 miles on it. It of course has the #243 heads but the solid valves and I'm having them CNC ported. I have an opportunity to buy a set of lightly used (whatever that means :eyes:) LS6 valves with the hollow stems and sodium fill on the exhaust.
The vavles are used and the guy says "... they have been resurfaced. The refacing of the valve consists of removeing .002-.003 off them to give them a new surface. The 30 deg. back cut is already pre cast on the valves machining it just trues it up to the 45 deg. cut, which helps your low lift numbers. Yes you can just drop these valves right in your heads (depending on seat condition), or you could put a valve job on them."
Not being a valve guy I just want to know if this is problem or not (using used valves that have been resurfaced)? Also, what would be your guess as to what they are worth?
Many Thx!
:confused:
Many Thx!
:confused:
